The back of the shifter does have a thrust washer #13 at Service Honda.
Clutch is 12 and 13.
LH threads on the crank!! and make sure you run "14 on the oil pump. It keeps the loose chain on.....
If there is a kickstart idler gear, there is probably a thrust washer on the back. I couldn't find it on the parts diagram.....
When you take that stuff apart, put a zip tie through it or tight on the shaft so if it takes 6 months to toss back together.
Or, line it up into an empty egg carton.
