Results 1 to 12 of 12
Thread: Honda hubs on a Kawasaki?
    Feb 2007
    NS, Canada
    25
    My rear wheels are essentially shot on my KLT250. Massive pitting, the outer rim edge is rusted through and they only hold air with tubes installed. Anyways.
    What are the chances that honda hubs fit on my KLT? (since 4x4" is a stupid rare bolt pattern, and I can't find replacement wheels). Anyone done this?
    Thanks!
    Rob
    Feb 2007
    NS, Canada
    25
    No bites? Anyone tried this? Or maybe can give me the size and spline count on a common honda hub?
    Thanks.
    Wichita, Kansas
    1,359
    Look for Polaris rims/wheels. Early 90s polaris trailboss. Im sure tons of others will fit. I've got a set that bolt up to my klt..and my 84 tecate.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Feb 2007
    NS, Canada
    25
    I see that the trail boss, and a couple other Polaris's may work. None have the correct rim size, but I'm looking at new tires anyways. My original question still stands if someone can answer if the hubs themselves interchange with something common.
    Also. I challenge anyone to go googling ATV 4/4" or 4 on 4" bolt patterns, and come up with something other than 4x4 -whatever rims, and avoid ripping your hair out... infuriating.
    Wichita, Kansas
    1,359
    Hubs are tricky, nothing to really cross reference. Rim's are much easier.
    Wheels from my 1995 mazda protégé lx... lol they are a 13 in
    http://www.myboltpattern.com/atv-bol...bolt-patterns/
    All KLT(all engine sizes) rims will bolt up.
    Tons of Polaris rims.
    84 Tecate rear
    If you want a real challenge, try to find rims that fit an artic cat (2000 250cc 2x4)... that aren't artic cat
    Sep 2005
    MICHIGAN
    2,027
    4 TIMES 25.4mm equals 101mm so it is 4x101 so I would guess 4x100 would also work.
    TIRE 25X12-9 KNOBBY R
    MY guess is those coarse spline hubs are the same as the 1985 KXT250 Tecate with 4 on 156mm pattern. If my guess is correct this is your only hub option but not if you want to run a 9" tire because 4x156 doesnt allow that.
    So buy some blaster rims or somethin , lots of models have 100 and 101 pattern
    86 T3
    84 T3
    86 KX250
    Wichita, Kansas
    1,359
    one of these days, I want to make a jig to allow me to drill a 2nd set of holes.
    Design it to bolt to the current pattern on a tire, and then have offsets perfectly lined up for a different pattern.. This may be 1 of my first projects with the 3d Printer once it comes in.
    Sep 2005
    MICHIGAN
    2,027
    they kind look like 1984 Tecate hubs but I think the studs used on them are larger than what is on newer atvs like Blasters so you have to use a drill/reamer/endmill and ream the hole to fit the studs anyway.
    86 T3
    84 T3
    86 KX250
    glendive, montana
    1,822
    I have put honda hubs ona yamaha, and yamaha hubs on a honda,and a klt 200. the yamaha hubs onto a honda is a tight fit as yamaha has slightly taller splines, but they will fit. so your options are anything you want for hubs the yamaha hubs went on nicely to the kawasaki and the tri-z uses a 4X100 bolt pattern. Unless your splie pattern is different then a 83 klt 200 a4a you shouldn't have any problems.
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    Just about any solid axle rear polaris rim is 4x4. IRS models are 4x156. If you absolutely can't find anything else and still refuse to use what is available, well that's your own problem. I'm assuming you want to use honda hubs with a 4/110 pattern, I tried to find hubs that swapped over to my klt 110 but couldn't find anything unfortunately.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Feb 2007
    NS, Canada
    25
    Thanks everyone for chiming in. Muthey - that sounds very promising.
    Thanks guys. I now know what to check out. I'm not being stubborn or anything like that, but where I live, there are virtually no 3-wheelers around. The ones that are around, are hondas, hence the reasoning for my desire for a honda hub swap. (Quite a few of them being parted out nearby).
    Anyways, I'll post up when I get proper rims, or come up with a hub solution.
    Rob
