Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
Thread: The all new Big Red 250es / 250sx 350cc big bore kits are in stock.
  1. #31
    Apr 2012
    AR
    75
    Quote Originally Posted by Mickey Dunlap View Post
    The 250sx guys are complaining they can't use all the power because the front end won't stay down. That's what I knew with our old 315cc kits, so they work better in the Big Red 250.
    Sounds like a good problem to have haha.
    I have to ask with the 350 kit do you think it will over heat for slow tight woods trail riding mudding and such? Or would the 315 be better?
    Also with the 350 kit and a matching cam, can it still be lugged around like stock in low rpms?
    About the clutch springs you offer, i have a barnett clutch and hd clutch springs im about to put in my 250sx, are your clutch springs comparable or stouter? Would i need them for the 315 or 350 kit since i have the barnett springs?
    Thanks
  2. #32
    Hyndman PA
    1,905
    Quote Originally Posted by Gator72007 View Post
    Thanks
    IMO all Honda air cooled motors need a oil cooler to keep the rockers and cam cool. I don't know anything about the clutch spring they have.
  3. #33
    Mar 2021
    St Croix County Wisconsin
    Will the 11:1 350 piston and stage 2 cam go into a Honda 250r?
  4. #34
    Aug 2005
    CT
    207
    No sir, the R is a two stroke engine which doesn't use a cam.
    Other companies offer big bore kits for the R series though, try Eddie Sanders Racing (ESR) for example.
  5. #35
    Apr 2020
    Carleton Place, Ontario Canada
    Anyone try front end reversal get a little longer wheelbase puts more weight up front, I have my SX Setup this way Also have the skinny tire conversion. It takes some time to get used to the new feel, especially with the skinny front tire. Lookout in the corners go in drifting sideways and you be fine. After almost a full winter I'm convinced that this is way better than stock in snow for turning ability. Im gonna get into big bore setup next fall/ winter, going to do the trx250 swingarm mod first.
