Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: The all new Big Red 250es / 250sx 350cc big bore kits are in stock.
    Hyndman PA
    1,905
    $335
    This is a 88mm 11:1 piston that will come with a sleeve and head gasket. Just re-sleeve you cylinder and let her rip! We have a new bigger cam but I'm going to wait on selling the stage 2 cam until I get in my bike, for now we have our stage 1's that will work fine for most trail riders.
Name:	2006-01-18 02.07.47.jpg
ID:	214646Click image for larger version.
Name:	2006-01-14 23.27.26.jpg
    Masshole
    2,191
    How much of a power increase does this yield?
    Any need to run an oil cooler?
    Im def interested, but curious how much more it actually makes
    Would def be nice to not be stuck in 2nd or 3rd on the bigger hills on the trails
    Hyndman PA
    1,905
    Quote Originally Posted by jeffatc250r View Post
    I'm going to dyno my stock Big Red 250 and a 85' 200x stock before I put the kit in so I will be able to give you all the answers. IMO all the air cooled bikes need the oil cooler kits.
    Just as a est. 100cc should give it 10hp by it's self and the stage 1 cam around 3 more hp. Stage 2 cam and ported head should give a strong 20hp more with a 400ex carb. So IMO est. should over double the hp the way I'm going to build mine.
    Jan 2008
    nc
    734
    How long is the wait for the 350x kits?!!!
    Masshole
    2,191
    What oil cooler setup is used? A universal or does something from a trx work?
    Will the stock carb work with heavier jetting or is a ex carb needed?
    Also will the stock valves and exhaust work or too restrictive?
    Could def use more grunt in the ole sped, but want to keep stock exhaust and carb if possible
    I like her quiet and stealthy
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    Quote Originally Posted by devilman View Post
    This. I volunteer my 350x as a tester unit...
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Worcester, MA
    1,117
    Will these kits work in a trx300 engine? 2wd, shaft driven model
    Dec 2009
    Oklahoma
    780
    Mickey, did you say it will work in a 85 200X motor, And if so what Is the cc's
    Hyndman PA
    1,905
    I can only do so much. Between fenders and this time of the year I' slammed.
    Hyndman PA
    1,905
    I have cooler kits, same as a 300ex.
    I'm going to run mine with stock carb and pipe first, then change to head work and carb.
    Hyndman PA
    1,905
    Quote Originally Posted by Keith Salyer View Post
    No, I'm dynoing them at the same time, then the 200x will get dynoed with my piston and stage 3 cam. I have also moded a DG pipe and a 30mm carb kit.
    Beau is offline First Time Rider Arm chair racerNew to the board
    Aug 2013
    schertz, tx
    86
    with 11:1 can you still run pump gas?
    Hyndman PA
    1,905
    Quote Originally Posted by Beau View Post
    With the cams I have, other wise just tell me you are not putting a cam in and I will lower the compression.
    Aug 2013
    schertz, tx
    86
    Quote Originally Posted by Mickey Dunlap View Post
    will the cam not work with a lower compression piston?
    Hyndman PA
    1,905
    The stage 1 would work with 10.5:1, but the stage 2 will need the 11:1.
