Originally Posted by
TheBlueWale
Gold shock spring, shortened front forks, Hoosier front tire, etc
It's always cool to see something like this come up
What a gem of a find. The front forks are stock other than the dampining rods being modded (assuming rob was doing back then what he does now). The way to lower them (1985) only, is to swap the small spring locations inside the fork tube. This lowers the ride height up front. And when you jump or loft the front end the tire will only drop it original travel length. The 85's have 3 springs inside and the 86's have 2 inside. You cant drop the 86 internally in its stock form.
The trike appears to be set up for a smooth track. Also rob cuts the rear spring to lower the rear to match the front. He showed me this trick while helping him at the shop. I got to cut 3 rear shock springs. You cut them heat them at the end and bend them then grind the end flat like oem. No adjustable strut needed.
It was a treat racing Robs personal 200r at the nationals. Lemme tell ya, they haul ass.
Shart Guard .......Use it !
Pink Powerwheels Barbie trike
1985 Crash and Burn champ
