Results 1 to 15 of 18
Thread: LED light bar on a 1985 Honda 250r?
    Nov 2013
    brawley, CA, imperial county
    125
    I just got my 36w 7in. Light bar and I don't know how to wire it up to the stock headlight wiring, has anyone done this before, I checked the forums but the only one I could find used a battery but that was a 12v light.
    Jun 2009
    Leander TX
    2,217
    I run a pair of 18W LEDs on my 85 250R along with my stock light.
    I wired them to run when I hit high beam - so I have the stock light and 2 LEDs on at the same time.
    On the 250R, I cut the high beam (blue) and ground (green) wires running to the headlight and added plugs to connect the new lights.
    I run off the stock electrical system with no mods other than the aforementioned splicing.
ID:	211937 Click image for larger version.
ID:	211938 Click image for larger version.
    toki is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2011
    wisconsin
    158
    check this one out. its a tecate but its the same principal.
    http://www.3wheelerworld.com/showthr...=led+headlight
    250r outputs AC for the lighting circuit. you need to either float the ground for the lighting circuit on your stator, or a 4 wire rec/reg monkeyed in somehow.
    also some LEDS can take AC current just fine.
    I routinely spill Hot McDonalds coffee in my crotch, just to ease the numbness of everyday society..
    Nov 2013
    125
ID:	211941thanks for the advice I'm gonna try it after a cold one because it's kinda warm outside right now
    Looks great, I'll bet it's BRIGHT!! Can never have enough light at night!
    Nov 2013
    125
ID:	211961got her mounted all that's left is the wiring, had to make a custom mount as the rigid mount only works for atv handle bars not atc handle bars
    Nov 2013
    125
    I have two green wires, one white, and one blue, do I use both greens for ground or just one?
    Nov 2013
    125
    Does anyone know which wires should be connected to the LED light bar, I have them stripped and ready to connect but I have 4 wires from the stock light and not 3 like the wiring diagram shows.
    Des Moines, IA
    1,303
    It's surprising to me that some people are connecting these directly to unregulated AC and not having any problems. When I connected 2 of the 18w 6-LED units to my Tecate with no mods, one of them blew within a few minutes. It probably wasn't the AC as much as the overvoltage coming out of the high output Ricky Stator in my machine, but I'd still worry about blowing them on a stock machine with a 55 or 60 watt lighting coil.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Jun 2009
    Leander TX
    2,217
    250R comes stock with a regulator.
    I added one to the T3 when I ran LEDs.
    For the OP - just connect the blue or white wire to red on the LED and one of the green wires to black on the LED.
    Nov 2013
    125
    OK thanks, the white is the high beam and the blue is the low beam, does the high have more power than the low?
    Jun 2009
    Leander TX
    2,217
    No. Just filament placement in the bulbs to change the light pattern.
    Des Moines, IA
    1,303
    Quote Originally Posted by jb2wheels View Post
    Ah, I hadn't realized that. That's what I did on my Tecate too. I also added a battery after I had trouble with the capacitor I had been using.
    Nov 2013
    125
    Thanks guys I got her all wired up with both high's and lows. I can't wait for Glamis tomorrow to try out this bad boy, thanks for all the advice guys gotta give credit where it's due.
    Nov 2013
    125
    I had to use both green grounds as I only tried 1 of them the first time and the light wouldn't turn on, I connected both of them to the black ground the second try and hot dam she worked great, even in the day it's bright!
