Originally Posted by
quicksilver
Google "lifan wiring diagram" then start reading them all. I can tell you from experience that it will usually take more than one diagram to determine the function of each wire. Wire color is irrelevant. Connector type is irrelevant. What you need is to know what each wire DOES, regardless of color or connector type. Then it will (should) all make sense. Your pics don't help because they do not show where each wire goes to/ comes from. You're gonna have pickup wires, charge wires, possibly gear indicator wires and as mentioned safety switch wires coming from the engine.
If you have problems with the Lifan electronics as I have. replace everything with factory honda crf50 electronics so everything matches. You will never have a problem again
Trikes:
1985 ATC 70 mod to 184cc
1984 ATC70 mod to 124cc
1983 ATC 70 Xmas restoration
Quads:
1986 TRX 250R
2002 TRX 400EX
2- LT80 for the kids
1986 LT 50
