Thread: rear brakes 200x
    Apr 2014
    usa
    30
    rear brakes 200x
    I am having an issue with the rear brake caliper, leaking fluid, have replaced the seals in it with a rebuild kit, but still leaks out of the back where the p-brake is. any advice?
    6,763
    Did you replace the e-brake shaft seal ?
    Another fix would be to install a e-brake block off plate with a gasket to seal up the leak .
    Nov 2014
    And yet another option would be to use the front caliper from a cr85 to completely eliminate the park brake.
    sanchez's Avatar
    sanchez is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    where ever i may roam
    228
    How bad is the leak?
    Appearing since '07
    Looking for a place to happen...
    Making stops, along the way
