I have an 83 yt175 with a mikuni pulse pump plumbed between the tank and carb (stock setup). From what I read, the 81 and 82 models did not feature the pump and stuck with gravity feed. When I was trying to get mine to start, I bypassed the pulse pump and went straight gravity feed. Guess what? Works fine.
So now I'm debating whether to eliminate the pulse pump with its extra lines, clamps, and fittings, or to keep it, assuming the engine still runs when I hook it back up.
What's the advantage to using this pump? What was "wrong" with the earlier years that they corrected with the pump?
