.160 custom spun wheel halves welded, They have no valve stem holes so you can put them where you need too!
the price 125 + 15 to ship!
Here is one that was installed at TF and rode all week Itrike can confirm it!
Here is an unground 250r hub inside the wheel too!
These will fit the COOL 86-87 tecates Pictures for the tecates will be at the bottom
10 inch wheel on 85 200x with 86-7 200x front hub!
OK lets clear this up!!!
1985-6 250r Clears the hub wont clear MOST caliper need to take 4mm off the 1st and last caliper fin
1985-6 350x Clears hub caliper bolt on deal
1986-7 200x WILL FIT!!
Also will fit 1st Gen 200x with hub swap from a 86-87 200x and small amount of grinding on the caliper!!!
1986-7 tecates clears hub and caliper with no problems
Will not fit the Tri-z with out putting honda forks and hond hub on your triz you need 86 tripples to do so! It wont fit with just changing the triz hub to a 250r one sorry i tryed!
