Results 1 to 10 of 10
Thread: 1984 XR200 help
    Aug 2013
    1984 XR200 help
    recently got this 1984 xr200 not the xr200r and i was wondering if anyone would happen to have a source on what carb model came on this bike?
    mines a bit wonky with a large stretched out looking spring
    the carb is a keihin PD 32A[E]VE cheap cycle parts diagram says this is my oem part number 16100-446-775
    also if you have this bike with stock jetting let me know that too
    thanks,adam
    Jan 2014
    Massachusetts USA
    782
    Don't worry about the number, the oem part number won't match what is stamped on the carb. Partzilla lists a #35 pilot and anywhere from 100-120 for a main for your bike. Also, my 79 XR185 has the same size carb as a 200, stamped PD-31AAQJ9, with a 130 main and a mystery pilot (no size stamped). Hope that helps, maybe someone with a factory XR manual will chime in.
    1985 Tri-Z 250
    1985 ATC250R
    Monroe MI
    5,787
    Aug 2013
    beautiful help guys thanks very much. i took the carb back off and the jets are 35 and 115.
    i found the slide was not going all the way in easily and sometimes not at all. it didnt look like anything was wrong though so i was puzzled, tried to clean it with carb cleaner still sticky finally i thought the guide pin for the slide looked a lil strange so i got a small file and ran it on the edges of the pin to clean them up and it slides in much better now
    really appreciate the help, now i have to wait til tomorrow to test her out
    Aug 2013
    i thought i had done it with the guide pin but it still gets hung up bout half way down the slide, starting to wonder if the slide is the wrong one for this carb maybe
    Aug 2013
    anyway i guess sometimes the carb body can get warped, hope thats not the problem
    but i have another problem where the kickstarter likes to not catch on the gears... i split the engine down and have it seperated right now but honestly the teeth dont look bad will get a picture here in just a minute
    well i found some threads on the 200x kicker but ill throw up a pic or too anyway
    here are some pics of the bad teeth probably going to go to my local atv/motorcycle shop tomorrow see if they have any better gears
    Manheim, PA
    5,816
    all the 200x and xr200s get this issue, you need to have the gears backcut and a shim spacer put in. I have 2 set of shim spacers yet, once you do this you never have the issues again. I finaly got outta these motors due to this issue, the higher the compression you build them the more noticeable you see this and need this corrected. yagerb on here can get your gears fixed up for ya, send him the set and he will have a machine shope fix them, he did it to mine build 200x motor.
    Aug 2013
    so i tried to get a picture of the diagram but i cant seem to get the picture on here. but anyway on the kickstarter diagram it shows a thrust washer number 14 but in the listed parts section it doesnt even have a 14. anyway i need this number 14 splined washer any idea where i could find one? thanks guys
    Oct 2013
    Wherever I May Roam
    3,757
    Slight possibility is the needle is bent. To check it, take it out and roll it between your fingers, or by the end on the edge of the table, and you will see or not see a slight wobble. It doesnt take much to bend them, and it doesnt take much of a bend to screw things up.
    Aug 2013
    About to order a carburetor and I need to know the stock intake size for the filter boot 34mm or 40mm
