Results 1 to 9 of 9
Thread: How to remove front wheel of Big Red
    Dec 2003
    59
    How do you remove the front wheel, brakes and all off of a 1985 Big Red? There are 4 small nuts on the right side fo it, I take them off and then the shaft is loose. But how do I take it all off so that the wheel comes off too? How about that small hole at the end of the front axle where those 4 nuts are? Do I have to turn that?
    JasonJ
    1983 Honda Big Red 200E
    1985 Honda Big Red 250 ES
    1985 TRX 125
    1985 Citation LS electro
    Hunter
    Trapper
    Eastern Long Island
    1,688
    Put the nuts and clamp back on loosley to support the axle then unscrew the axle from the fork.
    Lots O Trikes!!!!!
    May 2002
    Dublin, Georgia
    635
    Cable
    dont forget to disconnect the brake cable before you try to move the tire and brakes too far.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Dec 2003
    59
    Do you mean to unscrew it from where the 4 nuts are on the shaft itself? I tried that, I had a pipe on the wrench for more leverage and it did't even budge.
    1985 TRX 125
    Hunter
    Trapper
    May 2002
    Dublin, Georgia
    635
    yep
    If you loosen the four nuts then use a socket(17mm i believe) on the end of the axl you should be able to unscrew the axle. If ti does not budge get some rust breaker and let i soak a little while then try again.
    Dec 2003
    59
    O.K. now I know exactly how to do it. It was actually what I was doing. I sprayed a lot of liquid wrench spray on it, never budged. I had a breaker bar and a 17mm on it, with a pipe for extension and it still didn't move. Maybe I'll have to heat it a little with a torch. After all those years of mud, water, snow, it's caked on pretty good.
    1985 TRX 125
    Hunter
    Trapper
    May 2002
    Dublin, Georgia
    635
    Dont Foget
    Dont forget you can also try vibration therapy. You can tap on the wrench or ratchet some and see if the vibrations will help break it loose.
    Dec 2003
    arkansas
    42
    that front axle is gonna be a booger. easy does it. try, a little at a time, applying heat then spray w/good penetrating agent. repeat as necessary and don't get in a big hurry. u will find that by heating the housing that it reacts like a solder joint and sucks the solvent in. remember you are dealing with a steel axle and aluminum housing; tough combination and famous for seizing up. you will probably have to use 1/2" stuff and possibly cheater pipe or extension. just don't get in a big hurry and don't give up.
    good luck; hope this helps.
    Dec 2003
    59
    Yeah, I tries it yesterday, heated a bit, spray, tilt machine so spray penetrates. It's only my parts bike, I just wanna see how it all goes together instead of breaking it on a good Big red. I don't really need to do it, I'll try it this summer when it's warmer. Currently the parts trike is sitting outside under a tarp at -40 Celcius, of Farenheit, so it won't budge.
    1985 TRX 125
    Hunter
    Trapper
