Well have been getting parts made and customized for a honda 300 4x4 but decided to put the motor in a atc 250sx. Finally got all my parts.
Crank is from a 86 trx350d machined to fit the 300 honda cases. It's +2.5 stroke over 300 crank.
Next I used a 350x head that I had highly ported and polished.
The cam is a mega cycle performance cam for a atc 350x but built to opposite rotation because the 300 motor spins backwards this corrected that.
I had the cases bored out to accept a Wiseco 91 mm piston 10.5:1 compression for a xr500.
HD valve springs and hardend rocker arms
400ex carb for it. And ebc dirt racer clutch.
Custom cometic jug spacer and 116 length timing chain and cylinder was o ringed along with a copper head gasket. Cylinder is off a 350x.
Any opinions on how his engine will run in a 250sx a fun machine?
