Finally got all 3 gold rims for my 85 250r. Front one is in perfect shape but the back ones have a couple small scuffs I was wondering if anybody knows the best way or best paint to use to touch them up a little. Dont have to be perfect.
They are 85-86R 250R rims right? Then they are gold anodized. So touch-ups not an option really. Early air-cooled 250Rs were steel painted rims & "can easily touched up/painted."
Previously Owned:
1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
1981 ATC 185S
1984 ATC 250R
1981 ATC 250R
1983 ATC 110
1969 HONDA MINI TRAIL 50
TRIKELESS
you could give this a shot?http://www.jegs.com/i/Duplicolor/318...FZJj7Aod71sA_A
never used or saw it, but I would be interested in your results. I would maybe spray some in the cap, and use a detail brush to dab the scuffed areas.
good luck
MY FEEDBACK THREAD- http://www.3wheelerworld.com/showthr...ight=aldochina
im going to give that duplicolor a shot. im not worried about it until i find the little round inserts that go inside the holes in the rim anyways
