Progress.
For those of you who have drempt of a front fork mounted snorkel for your 3 wheeler, I have found the solution!! RV sewer hose is the answer!! Durability is still up in the air, but it's cheap so it can be easily replaced. I now have a very nice snorkel that mounts to the front rack and is almost unnoticeable when I'm sittin on the machine.
I made mounts for the upright part with exhaust clamps.
AAAAAANNND, the whole setup is completely removable thanks to this awesome rubber reducer that I'm using to connect to the airbox!
I took it off and cleaned it all with acetone and sprayed somebedliner on it. We'll see how well that holds up...
I also cleaned all the electrical connections and packed em with dielectirc grease.
I had this old stack layin around so I threw it on there too.
