Results 1 to 15 of 21
Thread: What's the difference between the atc 200s 200es and 200m big red trikes???
    Jan 2014
    Uniontown, Pa
    9
    Title says it all. I'm looking to trade my 1986 Kawasaki Kdx200 for a 1984 Atc200[?] I don't know if it's an S , ES , or M. I don't really know the differences so i can't tell. And i'd prefer not to buy something unless i know what parts i can and cannot buy. Can someone please tell me the differences in those modesl? S ES M thank you.
    Apr 2010
    Cold Lake, Alberta, Canada
    537
    The 200's are pretty similar to each other. Thier frames vary a little, cosmedic parts and thier drive trains.
    The engines are pretty much the same.
    The 200es is a shaft drive, where the 200,e,s,m are chain.
    So if you are wanting something that you wont be missing parts for and parts are relatively cheap, go for it.
    [B]
    Trikefest Alberta: 2017, 2020
    Trikefest 2015 A.K.A MUDFEST
    Coolpool: TURN!
    Jun 2009
    Leander TX
    2,217
    200s is smaller with 22x11x8 tires.
    Others are bigger with 25x12x9 tires.
    http://www.3wheelerworld.com/content...Technical-Data
    Oct 2013
    Wherever I May Roam
    3,757
    I'm not a hard tail expert but aren't the es and m versions electric start as well?
    Dec 2012
    812
    It will be pretty easy to narrow down what it is based on this:
    - If it's a shaft drive, then it's an ES.
    - If it's a chain drive with electric start, then it's an M.
    - If it's a chain drive with pull start, then it's an S.
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Nov 2012
    Waldoboro, maine
    791
    Chain drive electric start and hi low range is 200e
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Jan 2014
    Uniontown, Pa
    9
    I've never owned a shaft driven off road vehicle, is this better or worse than chain driven? cheaper to fix? easier to deal with?
    Blossvale NY
    4,563
    Quote Originally Posted by Girr68 View Post
    It's not cheaper to fix, but if you are half awake with your maintenance and change the rear end oil periodically, a shaft drive should virtually never wear out so long as you aren't abusing your machine in an extreme way. Chains have to be kept in adjustment and require replacement periodically.
    Like said before, if it has reverse and hi/lo range, it is a Big Red. The first Big Red's (200e) were chain drive and the years were '82 and '83. In '84 the Big Red got shaft drive and the model designation changed to 200ES. '84 was the only year of the 200es. So if you have a 200cc Big Red and it's shaft drive you know it's an '84.
    Like said before, there are fewer differences between the 200s and 200m. Basically the same machine beside rear tire size and the M is electric start.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    cap's Avatar
    cap is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2014
    Nevada
    163
    200M has the two piece rear fender like the "E" & ES Big Reds. They are hard to find replacements for.
    Specs page here.
    http://www.3wheelerworld.com/oldsite...Specpage.shtml
    MNhondaguy's Avatar
    MNhondaguy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2013
    fergus falls, mn
    203
    200, 200s and 200m are not big reds. 200e and 200es are.
    I'm not sure of differences between 200 and 200s. I think 200 is hard front, and 200s is soft? Both hard tails. 200m is a 200s with electric start. All chain.
    200e is chain, hard tail, soft front, hi/lo, electric start. 200es is shaft, hard tail, soft front, electric start, hi/lo, reverse.
    I've tried to straighten the, out myself but get lost in all the info and specs.
    83 ATC 200E(X) Big Red
    My YouTube- http://m.youtube.com/user/mazdarattiman
    My bros (hoopster3030) YouTube- http://m.youtube.com/user/hoopster3030
    Jan 2014
    Uniontown, Pa
    9
    I got it today! What do you guys think?
    Sep 2013
    Saskatchewan, Canada
    661
    I am liking it - looks like it is all there. How does it run??? If you replace some of the minor cosmetic items - it would be a clean looking unit. Now, get out there and enjoy it.
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    Looks like a 84 200es with the wrong rear fenders . Rear fenders look like they might be from a regular 200 . Good start to a good machine ,,, have fun .
    cap's Avatar
    Jan 2014
    Nevada
    163
    That is what I'm thinking too, Trike is a 200E or ES with the back fenders off a 200 or 200S?? How did they make that work? Looks good anyhow!
    May 2013
    St. Louis
    505
    200s is smaller and more of a sport bike with one piece fenders . Regular 200's are left side / right side with a trunk . You can make the 2 piece fenders " work " on a 84 bigred if you drill new holes . They don't line up or fit like they should , but if you need rear fenders ,,, better than nothing .
    Girr you seem happy to have it , just pointing out the rear fender " facts " Looks like a great machine . Clean it up , tweek it out . Believe me I have worse that I'm trying to bring back to life . Enjoy .
