Results 1 to 15 of 16
Thread: Tricks to removing dowel pins?
    May 2009
    S.E. Michigan
    1,251
    Does anyone have any good advice for removing stuck dowel pins? I've got my 350X motor torn down and have destroyed a few dowel pins trying to remove them. I've just been grabbing them with the vice grips (after testing them to see if they'll remove easily) and smashing them down flat and twisting. It is funny though how some remove so easily with just my fingers and then others are completely stuck.
    Is there any better way?
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    NEPA
    7,049
    Soaking/tapping very gently around the stuck ones. Then a very good quality pair of wire cutters/dikes.
    Cincinnati, OH
    3,289
    I use a Bolt or a punch that fits inside them,then take a pair of vice grips. The Bolt or punch keeps you from crushing them. If that doesnt work i use a little heat.
    "MR.Clean"
    May 2009
    S.E. Michigan
    1,251
    I wondered about the bolt in the middle, but just hadn't tried it. Thanks, I'll give that a shot.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Slidell, LA
    4,738
    Heat, heat, heat.
    Pacific NW
    4,255
    Did I read a post about 'freeze off' or something sorta new that helps?
    I know I've used freezing wart remover to shrink press in carb jets before.
    Quote Originally Posted by tri again View Post
    This man is correct. The hell with heat, freeze it out.
    Mexico
    9,014
    When I have had to use Vice-Grips to pull them I put a snug fitting bolt inside the dowel so that the Vise-Grip can’t distort the dowel when I squeeze it.
    Oops, I didn't see Xowners post.
    Apr 2010
    Indian Falls, NY
    1,289
    I heat it and then unload on it with a penetrating oil and either punch it out or pull it out/twist/wiggle it out. If that doesn't work, I'll heat it and shock it with water and then pull, and use penetrating oil if I have to. Usually works, but sometimes you might have to keep doing it if it's stubborn. Reminds me of the time I swapped a rear end out of a Chevy Suburban and have to repeatedly do that until a bolt came loose.
    Never heard the freezing technique before though, might have to try that.
    Mar 2013
    Southern Wisco
    96
    Easy-outs, has worked EVERY time for me.
    Honestly that's about the only thing EZ Outs are good for.
    Agreed, easy outs do take most of them out. As well as the semi crush with something solid in the middle and vice grips.
    All rebuilt motors get high temp copper anti seize on the dowel pins. Helps in the future........
    May 2009
    S.E. Michigan
    1,251
    Thanks for all the tips. I really love the idea of freezing them out. I have used the air dusters before to freeze stickers off on another project, the trick is to just spray them upside down so the liquid comes out. All dowels are now removed on motor #1, but I'll have #2 in the works soon, so I'll give the freeze spray a try there.
    Putting a tight fitting bolt in the middle makes so much sense, I feel silly for not doing that from the beginning.
    I'm also a huge fan of anti-sieze, Dirtcrasher. All dowels will be getting a nice coating of it on reassembly.
    Thanks all!
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by slashfan7964 View Post
    In most cases this is a no-no. Not that it doesn't get the job done slash, but when heated metal is quenched with water it can easily contract fast enough to create microscopic cracks and/or become hardened and brittle.
    Wart remover for the win...
    Apr 2010
    Indian Falls, NY
    1,289
    I won't do it on something small like that, but it was an idea, like something last resort. Normally I'd only do it on something rather large.
