You're butching wires and connecting to hot with absolutely no idea where they go or how the circuit is designed..
STOP NOW before you do horrible damage to your trike..or worse cause a short that ends up with a battery exploding in your face!!
And John is right, the neutral switch is a ground for the circuit..if the switch isn't grounding because of a corroded connection then this may be the only reason your trike won't start. Did you check there 1st?
If not get a cheap test meter and a copy of the electrical diagram.
Electric flows like water in a specific path, you just need to follow the path and see where the flow stops!! Switches and connectors are the number one suspect..
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
