http://www.ebay.com/itm/ATV-VOLTAGE-...d5f113&vxp=mtr
Thats the model i have used on at least a dozen or so Honda's to replace their existing one or convert them to DC. It does a very good job of regulation. That cheap one you used must be poorly designed to allow the voltage to go that high, it should have a point at which it cuts off. The ones i use are around 14.2v max and usually sit around 13.8v when the battery is fully charged.
The nice thing about these is they have a pigtail so they are easier to adapt to anything without having to make a plug specially for them.
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
