Thread: Dim headlights...
    Nov 2011
    Connecticut, USA
    50
    Dim headlights...
    So due to a transmission issue on my 1983 BIGRED, I had to swap a 185 engine that I had in place of the 200e engine. It still had a battery in it and for over a year, the 185 engine seemed to be recharging the battery just fine; well the battery is dead now and won't take a charge from my battery charger. As a result, my headlights are REALLY lousy.
    I went to BikeBandit to look up the part numbers on the headlights for both the 200e and a 185s and I see that they are the same identical bulb (I was thinking that perhaps the 185 took a lower wattage bulb - same exact part numbers). So my question is, what can I do to improve the lighting?
    My 1981 185s runs the headlight dim at idle (as you would expect), but it works very well when under load. When I put the BIGRED with the 185 motor under load the light is barely on, making night rides, which due to work I am subject to if I want to go out, pretty lousy on that bike. Would unhooking the dead battery help? Or am I going to need to get a new battery?
    1981 Honda 185s
    1982 Honda 110 (junker under a tarp for now)
    1983 Honda BIGRED-185s Hybrid
    1985 Honda BIGRED 250ES
    1985 Honda 250sx
    1983 Kawasaki KLT250a
    Sep 2011
    New Castle, PA
    1,134
    If the battery won't charge, it's bad. Get another one and go from there. If you still have a problem, it could be your stator
    Gone:
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    333
    The 185 is not electric start like the 200E and the harness and wiring is different. I doubt the battery was charging.
    Here is a cheap source for bulbs if you have a NAPA Auto Parts nearby:
    http://www.napaonline.com/Catalog/Ca...349_0313997940
    Nov 2011
    Connecticut, USA
    50
    Bulb is brand new. Stator is brand new also.
    I know what you were saying about the wiring harness, but I drove it with the 185 motor for over a year and the battery never wavered. Also, I would use the headlight with the engine off setting up during camping and stuff, and when it would start going dim, I would run the bike and the battery would come back strong.
    1981 Honda 185s
    1985 Honda 250sx
    Jul 2011
    Eau Claire, WI
    1,188
    Why are you still using OEM bulbs?
    There have been many advances in technology since the early 80's. Get a halogen bulb. Much brighter. Only $7.
    If that isn't enough there are LEDs that will fit the stock bulb sockets.
    86 Honda ATC 200X Frankentrike (Project)
    80 Honda CB650C Conversion (Project)
    3WW Feeback Thread For DasUberKraut
    Retired Machines - 02 Honda TRX 300EX, 85 Honda ATC 250SX, 84 Honda ATC 200X Astro Kit, 85 Honda ATC 70, 85 Honda ATC 200 Auto-X, 83 Honda ATC 200E Big Red, 84 Honda ATC 125M (X2), 82 Honda ATC200, 81 Honda ATC 185S, 81 Honda XR250R
