Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 41
Thread: 1986 and 1987 Honda atc 125m Information Thread
    Van down by the river
    3,874
    I am starting this thread because lately a few of us have picked up 2nd generation 125m's (1986 and 1987's). I searched a few post with the search feature but came up empty handed on most of my questions. I didn't know if I was going to resell this 87 or keep it but I think I have decided to keep it. I simply fished for new trikes and this one landed in my lap for a very small price that I could not pass up. Its an 87 of course I'm going to snatch it...duuh
    By the way for you folks that don't know much about them, these have reverse!
    #1. I would like to know other than the headlight, what other parts interchange. I doubt many will from my research.
    #2. I also would like to know the production numbers. All the links I have seen posted about the numbers do not have this particular model listed.
    #3. Also the rear rack mounting pieces that screw down to keep the rack in place, look to me to be the same as the 250sx. Does anybody know if someone has re-popped these? I know I had an 86 that used these.
    #4. Plastic gas tanks. I have searched for these as well. Does anybody know if they were offered for this trike?
    #5. I am sure this has been addressed but I am having a heck of a time getting the front axle off. A bearing must be seized. I know the 200es has the same silly round axle on the left end. I am heating and beating but does anyone else have a trick other than that?
    I know there are a few of you guys out there that are very sharp on these Shortline and Howdy I'm calling you guys out. So If you knowledgeable guys could please take a minute or two and share with us, we would appreciate it. Also if there are any other OWNERS or past owners that are curious about something else with these cool rare atc's feel free to post up your questions.
    Attached Thumbnails Attached Thumbnails DSCF0140.JPG   DSCF0139.JPG   DSCF0138.JPG
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    6,778
    No plastic tanks have ever been made for the 86/87 that I know .
    To remove the front axle heat the brake drum were the axle goes threw it and use an air impact to break is free by spinning the axle . Some times the bearing spacer is the issue and if its that cut the axle and buy another lol .
    I would like to know the production numbers as well , gotta be a low number .
    Howdy's Avatar
    Celina, Ohio
    10,079
    Mike is 100% correct. I have heated the front axle before and had good luck getting them out. I heated it red hot and then sprayed the joints with pb blaster, then waited a while heated it again and repeated the spraying. I did this 4-5 times and the axle did come loose. It was siezed in the hub.
    Howdy
    3,874
    Well gentlemen persistence is key! I went out to the shop and in between other projects, I heated, beated and sprayed the joints down. I was able to break it loose and even save my axle. It was seized to the right fork, and drum/hub assembly. The spacer was the only thing that was loose. Thanks for the help. I have no idea what I am going to do about a tank yet. This one is nice on the outside but trashed inside and leaks. If anyone has a spare, dont hesitate to contact me. I may try a 200 tank but I think they mount differently.
    Thanks for the encouragement!
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    Aug 2010
    Centerview, MO
    479
    Hey captianweeezy I have a spare tank I could sell. I will be able to get pics of it tomorrow.
    1986 Honda 200x 1985 Honda 200x x3 1974 Honda atc90 1979 Honda atc110 1987 Honda atc125m1977 Honda atc90 x2 1981 Honda atc110 1983 Honda atc110 superior blue 1984 Honda atc250r x2 1986 Honda atc350x 1984 Honda atc auto x 1982 Honda atc70 1985 Honda atc70 1983 Honda atc200e big red
    YEAH I LIKE HONDA
    Nov 2004
    Waterloo IL
    2,701
    I like it!
    May 2009
    Minnesota
    457
    As far as the production numbers, the 86 model year ran right around 8,500. I don't think we were able to track down the stats on the 87's however.
    BTW weezy if you do ever decide to part with it, pleases give me a shot at the front rack first . Been searching for my 86.
    1982 Honda Big Red 200e
    1985 Honda 200x- sold
    1986 Honda 125m- sold
    1986 Honda Big Red 250es
    Aug 2007
    Montana
    857
    The '86 '87 & '88 200sx electrics are the same as the 2nd gen 125m head lite mounting bracket is also the same!
ID:	182511Click image for larger version.
Name:	IMG_0642Z  The cleaned up 125m.jpg
    DO the Best With What you got !
    My Feed back :cool
    3,874
    Quote Originally Posted by RDH/86200X View Post
    I will be waiting! Thanks. I will pm you my info! I am swapping the tires this week and cleaning the carb. I hope the mosh's can do some good with that seat pan booger-ed up in the front. I wonder if the 00s rear trunk is the same. Mine has no cracks but is super faded.
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    6,778
    Did you try the CDI box from the 200sx ?
    Quote Originally Posted by Ol Deuce View Post
    Aug 2007
    Montana
    857
    That is one item I didn't look at !
    My Feed back :cool
    3,874
    How about a seat? I just checked a 200x and its NOT the same. It looks close but the M has this clip that fits under the tank. The X does not.
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    3,874
    I am having a problem now that I got new tires for it. I planned on going to the one piece rims which I have from a 200s. Problem is the bolt holes are bigger on the 125ms hubs. I am sure I can drill these out but then I have another problem. The holes are now too close to the rim to get an impact on them. I suppose I could swap out the hubs but I am still faced with the front rim issue as well. I hate knowing I have tons of rims but cant us them. I have found 2 parts trikes but who knows when I have a chance to get them.
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    3,874
    So I have been working on this 87 125m off and on when I have time. I picked up a 1987 trx 125 and thought with a little luck the seat and exhaust would be interchangeable. This is not the case. I did get the wheel situation figured out though. I used hubs and rims off a 200s on the rear. Then on the front instead of trying to change out the hub, I mounted a tire on a rear rim from the 87 trx125. Fit is perfect. I hate split rims and tubes as well.
    Bought a new carb off ebay along with a new petcock and also bought a used tank from RDH/86200X. The tank had rust in it so I purchased a gallon metal rescue. It worked great. I wish i would have taken before and after pics on my digital camera instead of on my phone. The results were awesome.
    So one major thing I have not been able to track down or find are the knobs to bolt the rear rack on with. If anyone has one, I would love to borrow it to have my buddy's machine shop make a dozen or so. Sx are the same as well.
    I was able to get a good deal on some kenda front max size 22x11-8. Needless to say(see pics) these are going back! They are the correct size but there is no way they will work. So just a tip, no idea why they are so much bigger than all the others this size but stay away.
    So all in all I have a good running 87 125m that is fun to ride and I don't have much in it.
    This will not be a show queen so I don't plan on restoring to a shine. I will be on the lookout for a few things such as a new/used seat pan to send to cosmic quads and maybe an exhaust.
    I will have it at trike fest for sure so if you want to ride it, come see me.
    Attached Thumbnails Attached Thumbnails DSCF0303.JPG   DSCF0302.JPG   DSCF0301.JPG   DSCF0272.JPG   DSCF0271.JPG   DSCF0270.JPG
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    6,778
    I have a good 86/87 125m seat pan if you need one also an aftermarket blue seat cover . I haven't tried one but was told a 200s foam will work .
