Results 1 to 10 of 10
Thread: Cleaning jets with a welding tip cleaner
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    333
    I am planning to buy a welding tip cleaner from a local auto parts store to clean a #95 main and #38 slow jet. The tool lists #6 as the smallest tip cleaner size, is that small enough? Has anyone had a negative experience with the tip cleaner, like it abrades the jet too much? The jets are so clogged that I think a carb kit is my only other option.
    OHIO
    2,857
    Your best bet is a good wire brush that you or I would pluck wires from with pliers and clean the jets. Save your money......welding tip cleaners are too big of a diameter....... They do not work in that small of an orifice.........compressed air, carb cleaner and swabbing of the jets with a tiny wire........again and again and again..... then 2 more times.....
    ScreaminRed's Avatar
    ScreaminRed is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2013
    NC USA
    391
    I heard guitar strings work well also. Haven't had to try it yet, but sounds like a great idea!
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    '11 Electra glide Ultra Classic
    My feedback thread: http://www.3wheelerworld.com/showthr...or-ScreaminRed
    Cincinnati, OH
    3,289
    http://www.ebay.com/itm/Motorcycle-A...-/161104997715 Sure looks like a welding tip cleaner to me. They also work very well!
    "MR.Clean"
    Mar 2013
    Baldwin, Wi
    603
    I have always used the wire from an old clutch or brake cable it works great. Whatever you use be careful not to hog out the jets. The soft brass is easy to distort the hole making it flow more than it should.
    85 Tri-z Basket Case
    Mexico
    9,014
    No. #6 wire won't pass throught a Keihin slow jet, but it might on a Mikuni. Not worth the money if you are buying it just for this. If a hole is plugged shut I use a sewing needle to break through and then gently rotate it as I push it in. Then I use carb cleaner, toothbrush and even some 2000 grit sand paper if needed (only on the outside of the tube to get the fuzz off). Then a puff of air to make sure its clean. Use a light in the background to check for obstructions and odd shapped holes.
    1,641
    I have had good luck with guitar strings.The smallest jets I did we're out of a 125.
    Lancaster, PA
    1,738
    Quote Originally Posted by Xowner View Post
    Xowner is right this is the tool, it goes much smaller then a welding tip cleaner, I have both. A wire fron a wire brush will also work.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    JustEnough's Avatar
    Oct 2009
    Elk Grove, CA
    333
    Found a tip cleaner at a garage sale for 50 cents that goes down to a size ZERO that was small enough for most of the jets I was cleaning. A major score for me.
    The rasp part of the tip cleaner was so rough that it seemed like it would ruin a jet in a hurry, so I plan to only use the wire part of each cleaner.
    louisiana
    1,499
    i use torch tip cleaners all the time.even used them in a drill a time or two.
    Signature pic removed,becuase of no helmet.
