Results 1 to 9 of 9
Thread: Honda ATC90 aftermarket (homemade) exhaust/muffler...will this work?
    Dec 2012
    812
    I need a muffler for my recently purchased '77 ATC 90. They seem hard to come by. I found this muffler on eBay...do you think it would do the trick?
    http://www.ebay.ca/itm/110cc-817-Min...#ht_616wt_1170
    As it is now the trike has a straight pipe from the engine out the back. I was thinking of cutting the muffler off the pipe on this eBay one and welding it to the pipe that's already on the trike. What do you guys think? I don't know much about back pressure/jetting, etc. so not sure if I'll have to do a bunch of mucking around with things after. But the way I look at it putting this muffler on has gotta be better than the way it is now, running with just a straight pipe?...
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    MN
    3,263
    Just my opinion... I think it would work fine. The 90 isn't a huge monster of a motor or nothing. A basic little muffler would be fine. I have seen more than a few of the 110's now with a small tractor muffler on them from the local Runnings Fleet & Farm store, they sound good and run fine with them. So anything is possible with some fabrication.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Mar 2013
    Central PA
    2,362
    Just remember, thats off one of those really small chinese quads. But hey, its cheap enough that if it doesnt work your not at a total loss.
    Regardless its going to be better than what you got now. Just make sure it stays packed and your fine.
    Dec 2012
    812
    Thanks guys. I decided to go ahead and order one. Like you say, I'm sure it will do the trick.
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Jul 2013
    mo
    327
    Please post pics of the build . I'm very interested
    Dec 2012
    812
    I finally got my brother-in-law around to weld this aftermarket muffler on my ATC 90. We cut a chunk of the header pipe off the muffler as the bend was going the wrong way, and instead kept the stock header pipe that was already attached to the cylinder. We added a "filler" pipe in the middle with a bend, then attached the muffler to that. The muffler still had one stock bend in it that fit perfectly through the frame. I'm happy with the way it turned out. None of the exhaust rubs on the frame at any one point, and the muffler's mounting bracket lines up nicely with the rear cargo rack to fasten in place. Sounds a lot nicer than the straight pipe that was on before. And for 30 bucks, I figure it will work just fine
ID:	178685Click image for larger version.
ID:	178686Click image for larger version.
ID:	178687Click image for larger version.
ID:	178688Click image for larger version.
ID:	178689Click image for larger version.
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    New2Tri-Z's Avatar
    New2Tri-Z is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2012
    Redding, CA
    380
    Looks good man, I'm sure it will work great.
    Currently Owned
    1986 Yamaha Tri-Z 350???
    1985 Honda ATC 70
    1985 Honda ATC 250R
    2006 Suzuki LTR450
    2005 Suzuki LTZ400
    2005 Polaris Predator 50
    2004 Polaris Predator 90
    2-Honda Trail 90's (need to be brought back)
    Feedback Thread http://www.3wheelerworld.com/showthr...-for-New2Tri-Z
    MN
    3,263
    Looks nice!! Not bad for $30 at all....
    Jul 2013
    mo
    327
    great work man
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
