Results 1 to 7 of 7
Thread: Signs of a bent valve?
    Mar 2013
    Minnesota
    441
    My 200x has been a ! just rebuilt it..put new rockers/transmission gears in it, new kickstarter and coil.
    Now...she still wont start, i think it might be a bent valve?
    If i have a bent valve....what are the signs of it?
    I do have good compression..so is it even possible to have a bent valve?
    ~~ATC's Currently Owned~~
    1983 Honda 200x - Main ATC
    1985 Honda 200x - Parts Bike
    ~~ATC's Previously Owned~~
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1983 Kawasaki klt 200a
    1986 Honda 200s
    ~~Other Toys Owned~~
    2012 Pro R 800
    1993 Polaris Indy 500
    2004 Yamaha 125
    1990 Thunder Kart - 250CC
    2001 Yamaha Blaster - 240kit, aftermarket exhaust, power reeds
    Sarnia, Ontario, Canada
    3,415
    Bent valve = no compression.
    So no worries there..you could still be out a tooth or two on your cam which will make it difficult if not impossible to get running.
    Only if you have your cam so far out of time that you have piston hit valve have you done serious damage to your hard work.
    Recheck your work, I'm sure it will become apparent why it won't go!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Mar 2013
    Minnesota
    441
    what would you check next? (this is the first time rebuilding a X)
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1986 Honda 200s
    2012 Pro R 800
    2004 Yamaha 125
    3,415
    Quote Originally Posted by honda200xguy View Post
    Since it's been apart, basically everything.
    1st remove the pulse generator and double check the cam timing is dead nutz..(manual has full details.)
    2nd reinstall the pulse generator and make sure it's dead nutz..(manual has full details on this too.)
    3rd double check all your electrical connections and harnesses are tight and secure..
    4th you didn't meantion if you had spark at all..if not then go down that path to troubleshoot..
    And have a spare plug handy..with all that kicking you probably have it pretty badly soaked. A soaked plug may be your only problem for that matter..
    You must have the manual, right? When you do get it running..change the oil right away. Last thing you want is to burn out those unseated rings because all that fuel washed the cylinder clean of oil.
    We'll be here as you go to ask questions..
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Mar 2013
    Minnesota
    441
    Quote Originally Posted by dougspcs View Post
    Changed the coil i didn't have spark before that now its PERFECT
    Going to go threw the stuff now and ill get back to you.
    and yes i have a manual
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1986 Honda 200s
    2012 Pro R 800
    2004 Yamaha 125
    3,415
    Cool, glad you have it figured..
    Again though change that oil..if you have been kicking away for any length of time it's likely to have a certain amount of gas in it.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Dec 2010
    York SC - USA
    29
    check your cam chain timing
