Results 1 to 15 of 59
Thread: My Honda 200e/s 2 wheeler conversion
    Apr 2012
    Georgetown,Ca
    101
    Here's my latest project, a honda 200 2 wheeler conversion made with mostly parts I've had sitting around. 200e frame and motor, 200s front forks and fenders, (front and rear) and a yamaha bw 200 swing arm. I will add more pics if you guys are interested!
Name:	Boonie Bike 004 (2).jpg
ID:	171615   Click image for larger version.
Name:	Boonie Bike 19.jpg
    MN
    3,263
    Cool! Keep the pics coming also interested in seeing this progress!
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    May 2013
    Cut and Shoot, Texas
    57
    heck yeah! show that bad boy off, I wanna see more
    The art of custom PowderCoating
    TxPowderCoating.com
    832-818-3905
    Larry T Moore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2013
    Indiana
    358
    *weeps at what was a 3 wheeler*
    MN
    3,263
    Quote Originally Posted by Larry T Moore View Post
    Normally i would agree if its a butch job, but so far its looking like he is doing it right.
    Nov 2009
    N Hollywood/ CA
    588
    Keep it up!
    May 2013
    Delevan, New York
    104
    Looks Awesome.... I Have A Rough 200es In The Garage... Gives Me An idea
    1985 225DR
    1983 Honda 250R
    1972 Honda Us90
    Jun 2012
    Arizona
    71
    Not bad should be really fun.
    Few things to help out from things I have learned from friends builds and mine.
    The jack shaft slack will drive you nuts!
    Since you are using an 83 big red you have to be really careful on the chain to prevent breaking the case or wearing it.
    The bw200 inner sprockets are 530 not 520 chain. Not sure if they make a 530 front for the 83 or if the 530 chain will clear the case inside.
    Might want to check. You can always cut the inner jack shaft sprocket down to a 520 but trust me, try to keep 530 on it.
    That chain is really under stress on speed changes and with the case being so closed in the risk is much more.
    The 200m my bud has broke many a front chain.
    My bw200 has not broken the front on me. Slack on it really annoys me riding it.
    Noisy and jerky!
    Try to get the angle of the swing arm pivot, front sprocket, and jack shaft all in a straight row.
    tack the bits in place and sit on the rear and see your alignment with the shocks compressed.
    The chain will always rub the guide on the swing arm but you can move the shock mounts around or the pivot to make it not rub most of the time.
    Saw one recently on a ride. Really neat way they did it up.
    They added a little plate to move the pivot back 3 inches and 3 beefy chain rollers right in front of the pivot as chain guides.
    One in the middle of the chain, one above, one below.
    This way the chain will never rub the swing arm and will stay tight in a line.
    As the arm drops the lower and center wheel hold the chain in place for the shaft.
    The front end will need work.
    Rode one that the guy cut the neck and pushed the front end out a few degrees. Guessing 5 or so.
    The bike was really twitchy and hard to control in rough stuff with the stock 3 wheeler nearly vertical rake.
    Flipping the forks around helped.
    Adding length to the forks really helps as well.
    The one I just saw had the kawasaki front end on it.
    They cut and extended it to make level the bike for the front is already low and the frame rake made it lower.
    Like this front end but with 3 inches added to it.
    http://www.3wheelerworld.com/oldsite...0bklt200cB.jpg
    Apr 2012
    Georgetown,Ca
    101
    I totally understand where you're coming from, I would never cut up a perfectly good 3 wheeler, this is made entirely of single parts that I have aquired from buddies, and /or previous projects, and believe me I still had a tough time cutting up the frame!
    Apr 2012
    Georgetown,Ca
    101
    I actually used a bw outer sprocket for the inner sprocket to match the stock honda 520 sprocket, and tried to keep it as tight as I could initially, hopefully it will last, if not I may have to add a tensioner of some sort. Thanks for all the other info on the front end stuff, this is all definitely an experiment for me.
    Apr 2012
    Georgetown,Ca
    101
    More conversion pics
    Here's a few more pics, I appreciate all the input so far...
Name:	Boonie Bike 1.jpg
ID:	171620   Click image for larger version.
Name:	Boonie Bike 3.jpg
ID:	171621   Click image for larger version.
Name:	Boonie Bike 4.jpg
ID:	171622   Click image for larger version.
Name:	Boonie Bike 5.jpg
ID:	171623   Click image for larger version.
Name:	Boonie Bike 8.jpg
    Apr 2012
    Georgetown,Ca
    101
    and some more pics....
    And some more pics, still getting evrything figured out, but trying to keep it as much honda atc as I can..
Name:	Boonie Bike 9.jpg
ID:	171626   Click image for larger version.
Name:	Boonie Bike 10.jpg
ID:	171627   Click image for larger version.
Name:	Boonie Bike 12.jpg
ID:	171628   Click image for larger version.
Name:	Boonie Bike 13.jpg
ID:	171629   Click image for larger version.
Name:	Boonie Bike 14.jpg
ID:	171630   Click image for larger version.
Name:	Boonie Bike 15.jpg
Name:	Boonie Bike 21.jpg
ID:	171632   Click image for larger version.
Name:	Boonie Bike 022.jpg
ID:	171633   Click image for larger version.
Name:	Boonie Bike 23.jpg
ID:	171634   Click image for larger version.
Name:	Boonie Bike 25.jpg
ID:	171635   Click image for larger version.
Name:	Boonie Bike 26.jpg
ID:	171636   Click image for larger version.
Name:	Boonie Bike 27.jpg
Name:	Boonie Bike 28.jpg
    Jun 2012
    Arizona
    71
    Thats cool!
    Nice Work!
    Got to fab up a neat skid plate and crash bars.
    Bud did not add those and broke the clutch cover a while back.
    Do you have any fold up pegs? If not might want to make some.
    Those stock ones with no give will take you down since the bike is so wide.
    Used some fold up ones from another year, think it was a 200s but can not remember.
    A guard and chain on the shifter is needed as well. To exposed as a bike.
    The look it has screams auxiliary fuel tank.
    Like the ones the old trail 90/110 bikes had.
    Might be a neat add one to offset the pipe on the opposite side.
    Like the way you made the stock pipe look like a stock bw! Nice retro look in the mounting!
    You might have room for the chain rollers i mentioned.
    Are you adding anything like a tab for the set screws that adjust the offset bushings?
    Or did you replace them with regular bushings?
    My buds bike how he changed the rake was to cut the front down tube out.
    Torched the top tube right behind the bracing and bent for his rake.
    Then he rolled a new down tube so it curved right into the old spots.
    Had to cut off the tank mount bolt and move it back a little.
    Gave the tank a little upward tilt. Not much.
    Your work is way better then my buds cobble work.
    Cant wait to see it all done so I can show him.
    I got another old frame outback that has issues. Might convince him to rebuild his.
    He built his swing arm out of pillow blocks, 2 inch square tube, and an old street bike swinger. Its ugly.
    Oct 2012
    Somerset County PA
    720
    That is awesome! Looks really good. I've seen some people do this before but not near as good ( I'm not talking about anyone on here) keep up the good work!. So what are you gonna do about a seat?
    Quote Originally Posted by Howdy View Post
    Yea, looked like a monkey ******* a football. LMAO
    Howdy
    Currently Own-
    84 250R My Baby/Project
    83 Yamaha 225dx
    79 Honda Twinstar - Big Ole Turd
    Heres My Feedback Page
    http://www.3wheelerworld.com/showthr...for-ColtonGG33
    Apr 2012
    Georgetown,Ca
    101
    More 2 wheeler Pics
    Actually doing some final assembly now, should be an interesting ride. The seat from the 200e still fits, as I did not change that part of the frame, I will also try to find some busted up old fenders that I can trim into side panels, and to fill the space under the seat. I left all the factory mounting tabs for these as well. I also welded in tabs on the rear to run a front 200s fender.
Name:	Boonie Bike 29.jpg
ID:	171666   Click image for larger version.
Name:	Boonie Bike 30.jpg
ID:	171667   Click image for larger version.
Name:	Boonie Bike 34.jpg
ID:	171668   Click image for larger version.
Name:	Boonie Bike 35.jpg
ID:	171669   Click image for larger version.
Name:	Boonie Bike 36.jpg
ID:	171670   Click image for larger version.
Name:	Boonie Bike 37.jpg
Name:	Boonie Bike 38.jpg
ID:	171672   Click image for larger version.
Name:	Boonie Bike 39.jpg
ID:	171673   Click image for larger version.
Name:	Boonie Bike 41.jpg
ID:	171674   Click image for larger version.
Name:	Boonie Bike 42.jpg
ID:	171675   Click image for larger version.
Name:	Boonie Bike 44.jpg
