Results 1 to 10 of 10
Thread: new engine for ATC90
    Mar 2012
    Uruguay
    8
    Has anyone fit a different engine on an ATC90 original frame?
    Jun 2013
    montreal
    16
    Quote Originally Posted by crottini View Post
    Chinese clones are popular choices. 110-160cc GY6
    Mar 2012
    Uruguay
    8
    Yes, I've read they are for the ATC70 but not so much for the ATC90, as far as I could tell. Then the electric start seems to br on the way of the original frame. Guessing that cutting theframe for it to fit would weaken it too much. I rather have it than not, but spending on mods more than in buying a new vehicle isn't possible at the moment.
    MN
    3,263
    They had a clone that had a bottom electric start and four speed auto, but seems everyone is out of stock on it now, maybe no longer made not sure. There was some issues with the intake and carb angle too if i remember right. If you got a motor thats got good cases, no holes from chain slap etc, i would just rebuild the top end on it and keep it.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    North Dakota
    1,643
    You can buy a adapter bracket for the Chinese motor to fit that atc 90 frame. Not certain how well they work I just have seen it used on a ct90.
    fastatc70 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Northbrookfield, Ma
    166
    Does the atc90 have the same bolt pattern as the 70. I built a Honda based 184cc motor that bolted into a atc125m. I didn't have the head stay but other then that it bolt in. The wiring was a little different but not hard to figure out.
    The china motors are the way to go with the little atcs. I have a zs155 modified to a 184cc monster. This this thing is a blast to ride in the sand pits.
    Trikes:
    1985 ATC 70 mod to 184cc
    1984 ATC70 mod to 124cc
    1983 ATC 70 Xmas restoration
    Quads:
    1986 TRX 250R
    2002 TRX 400EX
    2- LT80 for the kids
    1986 LT 50
    Mar 2012
    Uruguay
    8
    What do you think about this?
    http://www.chinesepartswholesale.com...ab1fdaf6ff7f84
    It sounds perfect as a new engine for an ATC90 original frame. Horizontal, Bottom Electric Starter (the Top would mean cutting the frame) and REVERSE! Is it possible?
    Mar 2012
    Uruguay
    8
    Now I've found a 125 engine with bottom starter and reverse that would also fit the ATC90 frame with almost no modification (it seems). But can anyone tell me if these people and these engines are reliable? No brand. They have at least two different sites that seem to be the same thing. Unfortunately the reputable stores don't carry this type of engine.
    http://www.shopatvpartsonline.com/08...2-1-n-reverse/
    http://www.highrpmracer.com/chinese-...c-p-10495.html
    Any input highly appreciated!
    North Dakota
    1,643
    I'm just not seeing it as a bolt into the 90 with this motors. Being they will bold into a 70 and a 90? They must be talking the newer small foot print motors like the 70. If you can get that adapter to be able to bolt the motor in they'd work.
    Mar 2012
    Uruguay
    8
    Yes, you mean DrATVs adapter, right? I'm counting on it once I can get an engine.
    But what do you think about the reverse, can it work with the 90 chain as is?
