Results 1 to 9 of 9
Thread: atc185 Flywheel stuck
    Nov 2011
    Canada
    221
    Picked up a 185 motor today for 20$ top end apart brand new piston. Anyways, I mainly bought it for the stator, But the Flywheel wont budge! It spins freely, i got the nut off with the impact. Seems corroded, but do i need a flywheel puller? Am i missing something?. ive also tried holding the flywheel while a friend hit the shaft with a mallet but nothing at all. Thanks to anyone who replies.
    1984 200x
    1985 "auto x" 200x. Had a rough life
    1982 atc200
    1983 atc200e
    198? atc?? w/ first gen 250r front end
    1982 atc185s
    Mount Juliet
    298
    The puller helps a lot. I've never gotton one off without a puller.
    If I can restore this piece of junk, anything is possible.
    My 83 (Well, now 85 thanks to a warped frame) 110 Build Thread http://www.3wheelerworld.com/showthr...3-ATC110-Build
    My 1981 110 Build Thread http://www.3wheelerworld.com/showthr...44#post1179444
    Worden18's Avatar
    Worden18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2013
    Minnesota, USA
    298
    It's gonna be tough without the puller. You can get a nice one that's made in the USA on ebay for $19
    http://www.ebay.com/itm/81-83-HONDA-...a92a3f&vxp=mtr
    My Trikes:
    1983 Honda 185s
    1986 Honda 250es Big Red
    1985 Yamaha 225 DX
    1984 Yamaha 200EL "Yamahauler"
    Jan 2013
    minnesota
    5,911
    Yup you need a puller 100% guaranteed. DO NOT TRY TO PRY IT OFF. They are specifically designed to wedge themselves onto the crank shaft when the nut is tightened. This is why they make flywheel pullers. It is doing EXACTLY what it should!
    Jan 2013
    minnesota
    5,911
    A Honda shop will probably yank it for free while you wait.
    Not around here
    Put oil on the flywheel puller threads.
    6,779
    "A Honda shop will probably yank it for free while you wait."
    Not around here either
    Not around here
    Howdy's Avatar
    Celina, Ohio
    10,079
    Back in the day I had the Honda Shop pull one for me. $10 for 2 minutes of work. I bought a puller for myself and never regretted it.
    Howdy
    Southern MN
    1,875
    Here is another one for 13.50 free shipping http://www.ebay.com/itm/Tusk-Flywhee...#ht_1089wt_873 These M 27 x 1 will work for hunderds of bikes and any 3 wheeler flywheel that uses a big threaded type puller, from Honda to Kawasaki. Remember the threads on the big end of puller are reverse thread, so loosen is tighten. If you have it cranked TIGHT and it still wont pop, get out the propane torch and heat the flyheel around the key. Once you get it HOT after 5-10 minutes, give it a little more of a crank on the puller and she should go. I have gotten some pretty bad ones off with this method before. They were stuck so bad that one of these pullers got wrecked the first try , when a buddy just put an impact on it and pounded until it mushroomed.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
