Thread: ATF vs fork oil?
    1,641
    ATF vs fork oil?
    Just wondering if fork oil works better than ATF in front forks?
    Southern MN
    1,875
    Yes, it deffinatly does. Back in the 80's, there were limited manufacturers that made fork oil, and it was hard to get. Thats why the many of the 3 wheeler manuals recommended atf. Now days oil has come a LONG ways since then. There are a bunch of companys now, the one I perfer best is Bel Ray. It is very good stuff. If you are a heavier rider, you could use 20wt, or a lighter weight or want that stock feel go with 10wt. I believe ATF is considered 7wt, just for future reference. Is this for your 350?
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    1,641
    Yes it is.I recently had them apart for new seals.Put in what manual said to use.I have Progressive springs on the way.I have some 10wt and 30wt.Recently saw a lot of posts on fork oil.
    IDK what you weigh but I'm 200lbs on a good day and I run 20wt. ATF is like 10wt.
    Even the level/height changes the action but we aren't Ryan Villapoto and don't have 2 mechanics. I can't be bothered to play with heights rather than just dump in the recommended ounces of oil.
    If you wanted to tune and play with that then you have more time than me! I'll play with upside down forks in the future
    Rittman, Ohio
    6,276
    Quote Originally Posted by jays375 View Post
    Depends on the forks, and how they are valved which is a fancy word for how big the holes are that the oils squishes through. Honda recommended ATF in their old stuff though its a little light for some riders in some applications. Way too light for Yamaha's. Tried it in an 85 TriZ for trail riding and the forks were constantly clunking out to full extension with almost no dampening.
    I never had trouble finding fork oil in the 70's and 80's. Probably not as many variations as today, but any shop had it on the shelves. The purpose of special fork oil (or ATF) is that it doesn't foam up when squished back and forth through holes. Hydrualic jack oil is pretty much 30 wt fork oil.
