Results 1 to 7 of 7
Thread: Forgot to Tell you all....
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    Everyone probably remembers me having problems with my 84 200x's......one would shift into 2nd but slip and make a ratcheting noise, and the other would go into 3rd and do the same thing....but all the other gears worked great.....Well this is what the problem seemed to be...
    After going through 3 of the very bottom shift forks (446R i believe thats what it had stamped on it...) something told me to check the shifting fork rod (the rod that goes through all 3 of the forks) well i rolled it on glass and it looked great....but something told me to put it in the drill press....so i did, and turned it on and WOW, that thing wobbled like a mother F'er....but i put a straight one in there and no problems since....just thought i would let you all know!
    Apr 2002
    s.w. michigan
    6,498
    tranny
    wow ,,, you battled those tranny problems along time.
    great to hear you got it fixed,,, that's great !
    john
    Jun 2002
    Mississippi
    2,552
    if you had it on flat glass and it did not tap when you rolled it then i can see how it is bent. i would believe the drill press was bent before i would believe that a bent rod would not tap on "flat" glass. jsut be sure to double check your findings before you put it back together.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    good job man, you didnt just give up and trash it like a lot of people like to do....good for you.
    200xbasket - i had a similar prob on my 84, and when i rolled the rods on a glass table they looked good, but if i got down real close and measure with something on each side as i rolled it slowly i could tell it was bent, and i did the same thing he did (drill press), and it was just a wobblin
    Indiana
    192
    a better option than the glass method is to take a couple of vee blocks and a dial indicator and spin the rod in the vee blocks and measure the runout. its a surefire method. thats what we do in the machine shops.
    Tim is the name
    85 350X(86 motor)
    83 200X(stripped down for a total rebuild)
    85 200S(project)
    JMiller's Avatar
    JMiller is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    V Blocks?
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    May 2002
    Texas
    2,670
    V-Blocks: Precision machined blocks for holding and measuring round parts. They have a "V" cut in the top of them so round parts lay down in them and are supported on the diameter.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
