Results 1 to 11 of 11
Thread: 83 185s with Offroad LED Bar light
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    I have an 83 185s that has only the AC lighting coil system (no battery). And I want to put an offroad led bar light on it for the headlight because the stock headlights are just not bright enough for me. In the service manual it says the 185s has 45w going to the headlight and 5w to the taillight. Now the OR LED Bar light has a power consumption of 30w and an input voltage of 9-32v. Will I have to use a regulator for this setup and is there enough power in the system to run this light and it function normally?
    http://offroadledbars.com/?product=7-inch-bar
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    Mount Juliet
    298
    Your main problem is that you have AC current coming from your trike, while the light bar requires DC. For this to work, you will need an in line rectifier to convert the current. After that, you should be good.
    If I can restore this piece of junk, anything is possible.
    My 83 (Well, now 85 thanks to a warped frame) 110 Build Thread http://www.3wheelerworld.com/showthr...3-ATC110-Build
    My 1981 110 Build Thread http://www.3wheelerworld.com/showthr...44#post1179444
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Ok so I looked and cannot find just a rectifier they are all regulator rectifier and those require a battery. So if I go that way what all will I need to add a battery to the system. Ofcourse I know a battery and a tray for a battery and a reg rectifier is there anything else?
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Bump......
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Bump2.....
    3. 85 200m
    fingerlakesny
    2,834
    prolly hafta buy a 200 m or something that has a battery ....just saying...
    250r dust runner
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    It can be done I just need to know how to wire it up and what is needed.
    3. 85 200m
    MN
    3,263
    This is easily done, be there done that. You don't "need" a battery but you will have lighting fluctuations if you don't have one. The battery acts like a filter, when the voltage drops with the RPM the battery keeps the light at normal brightness, think of your AC lighting now, how it brightens when you rev up the motor. The LED light will do the same thing but will also have an annoying flicker because the DC wouldn't be filtered without a battery or a large capacitor inline.
    All you need is a basic regulator/rectifier, you can buy a universal one off ebay or from any ATV/Motorcycle shop. It's a basic hookup four wires. On the 185 you have a green and yellow wire from the alternator/stator output, those go to the two AC wires on the regulator/rectifier, the output has a negative that goes to the frame and battery negative if you add a battery and a positive that you fuse and connect to the battery positive and light switch.
    The way i did it on a 185 was tap the regulater/rectifier input to the Yellow and Green wires at the stator then ground the output negative to the frame and connect the positive to the Yellow wire on the headlight switch. The taillight still runs on AC and the headlight runs on DC. If you want to add a battery you just run the output to the battery and then run from there to the headlight switch. Easy peasy...
    http://www.ebay.com/itm/ATV-VOLTAGE-...d5f113&vxp=mtr
    Example of a basic four wire regulator.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    HarrisoN* is offline At The Back Of The Pack Arm chair racerFirst time rider
    Bay Area, CA.
    156
    look up the thread about someone fitting HID lights to theyre 250r, think it was huffie? basically it has what you need to do in that thread.
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    I have a battery from my 250es with the battery box to use. Does anybody know how many watts the stock lighting coil puts out on a 185s?
    3. 85 200m
    MN
    3,263
    According to the service manual its 50w at 5,000 RPM. Generally a good rule of thumb is around 4 amps.
