Results 1 to 7 of 7
Thread: 1998 honda trx250 recon engine noise
    Aug 2011
    Bangor Saskatchewan, Canada
    91
    Picked up a used 1998 honda trx250 recon quad. Hasn't run for a couple of years, all I was told is that the engine started making noise so he stopped riding it. I put a battery in & it fired up but it's making a VERY LOUD fast snapping/clicking sound so I only ran it for a couple seconds. Some more info: the engine seems to crank over fine for about 1 turn but watching the flywheel you can see it gets "stuck" in one spot & you have to hit the starter a couple of times to get it past that "sticky" spot. What could be causing the noise? It seems to have good compression & doesn't smoke but I don't want to run it & wreck it (Noise is way too loud not to be concerned). Any ideas????
    ~ 3 WHeeLeRs 4 LIFe! ~
    NEPA
    7,049
    Needs a rod : ((... check your timing chain first, It's under the clutch cover,but it will be rod... Sorry
    Aug 2011
    91
    Quote Originally Posted by atc007 View Post
    You mean push rod right? That's what I was thinking as well.
    NEPA
    7,049
    Lol,,no,connecting rod. Valve clearance can make noise,,,but not like you're talking. Def adjust your valves first.
    Aug 2011
    91
    Oh. O.K, I'm just not understanding why the engine would become stuck in one spot from a bad connecting rod....Would running it out of oil wreck the connecting rod? or just the bearing? (The quad had very little oil in it when I got it) Guess I'll tear it apart & learn as I go.
    NEPA
    7,049
    Yes,,that is precisely WHAT running one low on oil does lol. It burnt the rod bearing,and it will stick in that spot. No,,you can't " work it free" lol.. It will need a new crank/ or rod if you choose. After you have verified what I've said. Your best/cheapest/smartest move will probably be to simply find a running engine. Or be very prepared to learn a LOT about the workings of an engine !
    Aug 2011
    91
    O.K, thanks for all the info. I have torn apart/rebuild good running engines (valves, rings, head gaskets, etc..), just never worked on one that had issues like this, so I don't know much about diagnosing weird noises. I'll price it out but, ya I might end up just swapping it out.
