Thread: 1983 ATC 200e Big red, can it have reverse????
    Oct 2008
    Reedsport Oregon
    856
    i stuffed a 200e (chain drive) motor in my x, i heard along time ago - 1990s there was a kit or way of transforming the hi lo range box which is fairly usless for me anyways (dune riding only) into a reverse gear? im positive i heard it can be done but havent ever seen anything on it does anyone know any more info?
    thanks
    Mar 2011
    Red Lion pa
    1,542
    There was a kit made by a company called Paltec. It included 2 sprockets and a chain that replaced 2 gears inside the hi-low gear box. The one in the thread below is now in the hands of another member. He looked into having them reproduced at local machine shop at a cost of $500 - $1000 set up fee and then another $150 per gear sprocket set. Good luck finding one! I've been looking for the same reason.
    http://www.3wheelerworld.com/showthr...ec+reverse+kit
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    Oct 2008
    Reedsport Oregon
    856
    dam sounds like no reverse no matter what.....
    Oct 2008
    Reedsport Oregon
    856
    i really dont want to give up on this reverse gear anyone else have any more info? is it a huge fab job to make a working reverse? what about just having a sliding extra gear that makes the bikes box rotate backwards?
    May 2011
    Connecticut,USA
    hawaiirider - I'm not sure this thread is still alive but has anyone thought or tried one of these Go Cart reverse gear boxes adapted to a Big Red 200e or similar without reverse? Looks like it could be modded to fit next to the chain cover with some creative brackettrie...Also a lot of these listed on Amazon...
    https://www.gokartsupply.com/gearbox.htm
    Nov 2019
    Florida
    1,047
    I had a 200e with reverse it had the kit installed, as mentioned before, you loose high and low range you will only have high range (plus all the gears 1,2,3,4)
    The chain in the kit was the weak link, the chain broke and cracked the sub trans housing, I ended up replacing the gearset and housing back to OE.
    It did work and worked fine. the kits do pop up on ebay, but they are not cheap.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
