sounds like you might have intake leaks. there should be an oring on the carb where it bolts to manifold. and between the carb and manifold there is a thick plastic gasket called the insulator. one side of insulator is smooth and other side has raised circles. smooth side faces o-ring and carb.
so it should be carb and o ring, then insulator, then paper gasket, then intake manifold. and should also be a gasket between manifold and head.
if it runs on ether as you say timing and everything else is all good
Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
