Has anyone ever put a turbo on a three wheeler in here?
can you? Is it even possible?
15, rode my first when I was 10. I own 4... I guess they Just talk to me![]()
<<<<<<<<<< Three Wheels For Life >>>>>>>>>>
(NEW) 1985 Yamaha Tri-z 250 My real #1
1985 Honda 250sx my "new" all original garage baby
1985 Honda 200m My first ride
1985 Honda 200x autox
There have been more than one attempt at turbo charging a trike on these boards. I tried searching for some threads, but only came up with these two. Our search function on this site has always been a let-down.
If I remember correctly, there may have been one, and only one, trike that was turbo charged correctly. The problem is, people take a small turbo from a small car and they think that it's so small it could work on a trike. Unfortunately, even a very small car is still 1600-1800cc's, which is massively larger than a 250cc trike engine. The turbos always seem too big to do any good at all. I'm sorry I couldn't find the threads I was looking for.
http://www.3wheelerworld.com/showthr...=turbo+big+red
An ex mod from .org has a turbo'd xr500 trike. Yes, it's possible.
But unless you're a plumber with an engineering degree, you're in for an absolute nightmare
I disagree with this statement. There really isn't much to the mechanical aspect of turbocharging. The hard part comes with the tuning. A turbo charger has one oil inlet and one oil outlet. The oil can be plumbed into the bikes oiling system or could be powered by a stand-alone oiling system just for the turbo. It has one fresh air inlet, and one fresh air outlet, which gets plumbed to the intake of the engine. It has one exhaust inlet (where the spent exhaust gasses turn the compressor wheel) and one exhaust outlet. Finding the room for plumbing and mounting the turbo can be challenging, but it's far from rocket science.
I have been playing with turbos on cars for almost a decade now, the only tough parts I see for turbo charging a bike would be creating a manifold for it and making sure you give it enough fuel. I have heard that 2 strokes are almost impossible to do because they dont have a consistent exhaust stream unless they have more than one piston creating regular gas flow to spool the turbo. Im 99% sure I have seen a 500cc bike that mymint has over on .org that is turbo'd. I guess if you have some basic tools and a welder than there's a way lol
its possible but you do not want a car turbo. i have seen turbo kits for my old 78 honda cb 750. its a tiny little bugger and would be the right thing to use. i have also heard of turbocharged hyabusas which might be easier to find kit for. cool idea but like manbear pig said it takes alot of work making the piping to hook it all up. and not quite sure how you would tap into the engines oil pump for the turbo or if that could drop volume from pump enough to hurt top end.
Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
I just found this turbo kit ... If you can put it together i guess its mission accomplished!![]()
http://www.chinese-parts-canada.com/...injection.html
That's actually quite affordable.
Ya, Thats what i was thinking. Are you crazy enough fabiodriven? New project???![]()
I friend of mine put a turbo kit on his '91 Indy 650 sled back in about '93 when the big dogs on the lakes started playing around with them.
His has a limiter switch... High boost (about 12 lbs) and low boost (about 7-8 lbs). Plumbing the system itself wasn't that bad, but the custom (airtight) airbox was a trick. He also had to run pressure lines to all 3 of the carb slide caps as the throttle slides wouldn't always drop down when letting off the throttle when higher intake pressure was present :O . That basically assures equal pressure above and below the throttle slides to assure neutrality and in turn proper carb throttle function.. kind of like how old school power steering works. Next an auxillary fuel pump with power jets was needed to kick on when a certain boost pressure is achieved to supply that burst of extra fuel along with the riseing intake pressure. His old piston ported Indy 650 was somwhere around 110 or so HP in stock config, but after the turbo it dynoed at about 140hp on low boost and over 160hp with full boost. Pretty impressive.
Thats the basics of what he had to do, but yes, a turbo can and does work on a 2-stroke. People turbo-ify 2-strokes on sleds quite a bit.. But I have never heard of turbo-ifying a 2-stroke wheeler.....Not saying it has not or cannot happen though.
It's definitely not exactly a bolt on and go undertaking unless you buy a kit designed for your application. Custom stuff gets a bit tricky.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
One of my buddys put a turbo a 350x pulling bike and on of they guys we race 70 with has one on a 70 with a 125 motor in it I will try to find some pics
it's all about getting a small enough turbo and tuning. http://www.honda-zoomer-tuning.de/ho...oject-raucous/ Panducky started an ambitious project a couple of years back by turboing a crf 450 motor with nitrous in a ruckus, unfortunately due to the economy he had to shut down shop and the project was never finished as far as i know. All the pictures are expired and these are the only ones that i could find.
just keep in mind
if you are gonna try this
that big red who tried it first in fabios first post said he used separate oiling system for turbo
and ride red 250r 's buddy did it on two stroke snowmobile so he had to use separate oiling system for turbo
just want to stress that i think tapping into engines oiling system could starve top end for oil
and with heat a turbo can make i wouldnt just use an oil box and mini pump but incorporate an oil cooler of some kind.
awesome idea though i hope somebody tries this and posts project on forum
