Results 1 to 7 of 7
Thread: 1985 honda 250es big red fork shock boot cover replacement with how to video
    rouseanator's Avatar
    rouseanator is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2012
    lynden washington
    209
    https://www.youtube.com/watch?featur...&v=3jJztBME-68
    This is a vid I made after trying to find shock covers for my big red they are from rocky mountain atv they are the 58 inch in black and its a perfect fit also made a how to vid to try to make it a little easier for ya hope this helps you
    Jan 2013
    Medfield, MA
    15
    nice vid. thanks.
    Jan 2013
    Medfield, MA
    15
    any chance you have a part number on the boots?
    Sep 2012
    lynden washington
    209
    just go to rockymountain atv and type in serch bar daystar boots and get the 58 inch ones
    Worden18's Avatar
    Worden18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2013
    Minnesota, USA
    298
    Thanks for sharing this. I have the boots for my Big Red and will be putting them on soon.
    Sep 2012
    lynden washington
    209
    I thought it would be harder from reading other forms but its really not that bad I just tore it down again to change the fluid in the shocks I would do it while you have it apart my drain plugs at the bottom wouldnt come out so I took the caps out on the top and pumped them out and used automatic trany fluid in them made a big differance and with it apart already would highly consider it, I also did the stering stem bearings that was kinda a pain you have to disassemble pretty much the whole front end but now no more wobble when I hit the front brakes good luck and let me know if you have any questions
    Worden18's Avatar
    Feb 2013
    Minnesota, USA
    298
    Quote Originally Posted by rouseanator View Post
    I'll keep all of this in mind. It makes it a little easier knowing there's people out there like yourself that give a damn and are willing to help. I appreciate it, thanks
    My Trikes:
    1983 Honda 185s
    1986 Honda 250es Big Red
    1985 Yamaha 225 DX
    1984 Yamaha 200EL "Yamahauler"
