i have a 85 200x and i got the axle out and i need to no how to get off the thing infrunt of the sproket so i can get the sproket off. Not the thing that is fixed onto axle the thing that holds the lil studs. HELP PLEASE!!!!
anyone?
Its simply held on by a big clip that keeps it from walking off. I can't think of the name of the clip at the moment. It uses a tool that looks like needle nose pliers that you stick in and when you squeeze, the jaws spread apart and open the clip.
Yup, what he said. I think its called a Circlip. The tool is loosly called snap ring pliers. You can get em pretty cheap at the auto parts store, give em a try, they usually work pretty good.
now that i looked at it some dum trailprotrailprotrailprotrailprotrailpro made lil welds around it so it wouldnt slide off is there any way to break these welds. And i no where to get the circle clip, so ill order that but i need to figure out hoe to get it off with these welds.
a punch and a will break the beads, that is why it was just tacked and not a big bead. and thank you! its called the damn sproket wouldnt go on, noone knew why, and a lost circlip, along with a lack of time (hours to get it done before you leave on vacation) i am not a big fan of welding but i didnt care anymore as there were so many hours into it it wasnt even funny.
85 Tri-z
38mm Flatslide
Boysen Power Reeds
DG Pipe and Silencer
Bored 1.25mm over
Wiesco Pistion and Rings
K&N Clamp on Filter
Compleating Restoration
o ok man thanks. ill get up pics for u soon.
