Results 1 to 15 of 18
Thread: DIY carb boot, advice welcome
    Gripit'n'ripit's Avatar
    Gripit'n'ripit is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    Rochester NY
    251
    I started this thread awhile back, but lost it in the crash.
    The carburetor boot on my 250R is getting pretty riddled with cracks and breaks, repairing is getting pretty ridiculous, and a new one is being difficult to find without paying $$$. For a quick fix i cut off the ring that meets the carb, and shimmed it into a boot for a different machine. It worked OKAY for a bit, but I need something more reliable and permanent. Still has chronic air leaks and the gas is eating away the gasket seal (didn't say it was a GOOD idea).
    Made a new boot out of stainless, but I'm worried it'll be more trouble than it's worth. Biggest concern is the new boot's a pipe that meets to a flat surface instead gradually flaring out to meet with the motor.
Name:	Shim carb boot small.jpg
ID:	158517Click image for larger version.
Name:	Inside shim boot small.jpg
ID:	158518Click image for larger version.
Name:	Stainless boot small.jpg
ID:	158520Click image for larger version.
Name:	Boot comparison small.jpg
    Anyone try this before? Will this just kill the machines performance? Kill the machine? Re-tuning or jetting of the carb? Better/cheaper/ easier options?
    81 250R Custom
    83 250R (in progress)
    98 Scrambler 400
    03 Bombardier Quest 500
    07 Polaris Predator (sold to klondike1020 )
    68 VW Dune Buggy
    What you've made does look like it may affect your performance, but it's a damn good effort nonetheless.
    If you got a bit fancier with your fabbing, I bet you could replicate that rectangular/tapered shape the original boot has. Then you'd never have to worry about it again.
    All in all, nice effort.
    May 2011
    eden,ny
    3,481
    jeswinehart has a thread up now about the different resins used to make parts and said he is going to put up info on the mold making.
    na
    5,702
    45 bucks is cheap for a intake built by the pros.
    http://www.ebay.com/sch/i.html/?_nkw...edirect=mobile
    Proudly NOT a member of
    "Team on the Teat"
    Quote Originally Posted by Mosh:1174103
    Well that right there pretty much solves your problem.
    Nov 2007
    Rochester NY
    251
    My carb is a 28mm. I should probably just upgrade my carb to a larger and more common size and a new boot.
    81 250R Custom
    98 Scrambler 400
    68 VW Dune Buggy
    Nov 2007
    Rochester NY
    251
    So I cut the pipe down and the boots installed. Connected the carb using a piece of filler hose for a cars gas tank.
    No problems with air leaks, holds study enough.
    Kills the throttle response a little. Need to do some carb adjustment, doesn't idle very well, guess i should be riding and not sitting.
Name:	Installed boot left small.jpg
ID:	158587Click image for larger version.
Name:	Stainless carb boot installed small.jpg
    Still looking to upgrade. Anyone have luck using a flat side from a CR250?
    81 250R Custom
    98 Scrambler 400
    68 VW Dune Buggy
    Apr 2002
    s.w. michigan
    6,498
    Don't know about the carb question but will say I too am very impressed with your fab skills.
    Sure wish I could weld like that ~ drool.
    Hats off to you Nick, darn fine work !
    john
    Aug 2004
    Ab Canada
    4,368
    That large long gap between your piston intake and carb is whats causing the crapy low speed performance too much volume not enough pressure difference to pull/ push the fuel in, shorten it up as much as possible...should smarten it up on the low end, nice work!
    1985 Tri-Z-
    Nov 2007
    Rochester NY
    251
    I'm not that good a welder. Friend helped me, and that didn't come out nice until after the 2nd, 3rd, and 4th try. Have some other failed attempts sitting on the shelf. A good learning experience.
    Shortening the distance makes sense. I'll have see what imporvements can be done!
    Still gonna try to upgrade. Have a CR250 flat side with a decent boot. Gonna try to put it in this week. Not sure if i'll be able to get used to a twist throttle. Which may lead back to the current set up (just shorter)
    Thanks for the feedback guys.
    81 250R Custom
    98 Scrambler 400
    68 VW Dune Buggy
    Aug 2004
    Ab Canada
    4,368
    Think you might find with the larger carb it will get worse...with the long tube, mikuni makes rubber intake flanges for carbs...if you can weld up a flange it should make life a bit easier,,check out sudco's website
    1985 Tri-Z-
    Ranvier is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2016
    Phoenix, AZ
    307
    I'm bumping this thread because all my 350x airbox/carb tubes are short. I have done multiple searches and tried a heat gun and boiling. The wintergreen oil treatment made them more pliable but they are still a touch short and after a good jump, they pop off. Next would be notching the airbox or moving the mounting tabs but I was thinking even a very small 5mm shim between the intake and rubber carb boot would make a difference. Obviously, I don't want to hurt performance but all the used tubes I am buying are still short. Any thoughts guys?
    Slidell, LA
    4,738
    Quote Originally Posted by Ranvier View Post
    what do you mean they are "short" Are you referring to the distance between the airbox bell on the carb and the air box is to long, making your OEM boot to short? If so, is this because you are running a different carb?
    Sep 2016
    Phoenix, AZ
    307
    Stock carb. Yes, the distance you described is too long. Out of four boots, I made one work but had to pull the carb back from the intake a little so the carb (engine side) no longer sits in the flange of the rubber intake boot.
    Slidell, LA
    4,738
    What isn't stock then? If everything is oem from head to airbox, everything should work perfectly. Do you have an aftermarket intake boot or aftermarket airbox, or????
