Results 1 to 8 of 8
Thread: Where to route 2 carb vent hoses on Tri Z??
    May 2003
    Houston, Texas
    2,409
    Tim Sr said one of the carb vent hoses should go to the airbox the other should go down the frame toward the ground.
    Does anyone have any pics of this for me to see...??
    Thanks
    Darius
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    yes, the one hooks up to the airbox, and i dont see another. there are two more that (on mine they are yellow from the years) are up where the slide goes in and they just get routed through the two clips on the bowl bolts (about 5 inches long or so)
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    DG Pipe and Silencer
    Bored 1.25mm over
    Wiesco Pistion and Rings
    K&N Clamp on Filter
    Compleating Restoration
    May 2003
    Houston, Texas
    2,409
    Wait....I need some help here...can someone shoot a pic of thier hoses from the carb...I am confused!!
    darius
    Dirtbikes:
    1988 Yamaha DT
    May 2003
    556
    here
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
    May 2003
    556
    another, i also got a question, if you eliminate the airbox what are you supposed to do with that hose?
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Its not really a big deal, its just a vent tube, the only reason it goes to the airbox, is so that no dirt gets in it, but that has never happened to me, mine just point down on my carb (I have a pod filter), and it works just fine.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    May 2003
    556
    alright, i was just going to run a hose on down somewere anyway
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
    May 2003
    Houston, Texas
    2,409
    Slippy,
    Thats what I call service...thanks a million!!
    Darius
    Dirtbikes:
    1988 Yamaha DT
