Results 1 to 13 of 13
Thread: Are Vesrah gaskets any good?
    Nov 2011
    Canada
    221
    Hey, the Vesrah gasket set contains everything i need, but I am wondering if they are worth buying? They seem kind of cheap and i have heard mixed results. Obviously i want the better gaskets but this is the kit with everything i need. Thanks.
    1984 200x
    1985 "auto x" 200x. Had a rough life
    1982 atc200
    1983 atc200e
    198? atc?? w/ first gen 250r front end
    1982 atc185s
    6,807
    Yes very good gaskets .
    Nov 2011
    Canada
    221
    Thanks alot for the advice!
    1984 200x
    1982 atc200
    1983 atc200e
    1982 atc185s
    Sarnia, Ontario, Canada
    3,415
    My personal experience with Versah wasn't good..I bought a top end set for a 225DR I did a ring job on.
    The head gasket wouldn't fit over the dowels in the head by a good 2mm.
    I ended up buying the OEM..I suggest you do the same.
    Doug
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Southern MN
    1,875
    I second that. That would be my second choice after OEM, I would recommend Vesrah for ANY machice. They are made in Japan, same as OEM, and they are very good quality.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Nov 2011
    Canada
    221
    Thanks also Doug and Yamaha_Rules69. 2v1 so i guess vesrah is a good choice.
    1984 200x
    1982 atc200
    1983 atc200e
    1982 atc185s
    fingerlakesny
    2,834
    i have had great results with them also... works 4 me...
    250r dust runner
    ontario
    1,131
    I won't run them in any of my 4strokes bikes. I have never had a problem with them in my sleds tho
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Same here, I just toss the head gasket.
    Nov 2011
    Canada
    221
    I heard the head gasket was junk. Is it really that bad though?
    1984 200x
    1982 atc200
    1983 atc200e
    1982 atc185s
    MN
    3,263
    I have used the Vesrah top end kit and the full engine kit on a half dozen 200's now, and a couple 250's, i never had a problem with them, they line up good, seal good, never had anything to complain about other than the oil seals not being included. If you are rebuilding the top end just be aware that the oil seal for the camshaft on the pulse generator base is not included, and other 200's that have a decomp lever that oil seal is also not included. You have to buy an oil seal kit separately but thankfully they are not that expensive.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Sep 2005
    MICHIGAN
    2,027
    I've had a couple head gasket failures on my KX250 motors but all worked fine on my LT250R and 84 KXT. Gonna try to heat the head gasket without coolant first next time though. I think the Kx failures are part design and my fault with the head stay.
    Who doesnt want an OEM head gasket though?
    86 T3
    84 T3
    86 KX250
    Nov 2011
    Canada
    221
    Wow thanks for all the reply's! From what i hear it's worth a try. If it leaks or is junk its not a lot of work to pull the motor and try a different kit.
    1984 200x
    1982 atc200
    1983 atc200e
    1982 atc185s
