Thread: atc 70 / lifan 125cc engine starting help!!!
    Apr 2010
    clarenville
    36
    hi i have a 84 honda atc 70 bough it as a roller so i deiced to put a lifan 125 motor into it , once i got it all hooked up and running ( runs like a clock) . where the motor is for the mini bikes not trikes the kick start kicks back and i currently jump start it , i was wondering if anyone has ever done this and how they got the kick start to work i know that i can put the left side casing and pull cord and sarter cup off the 70 motor for the pull start but where i bough it as a roller i don't have the motor and the pull start assembly is about 150-200 on ebay , anyone got any ideas?
    Jordan patey
    85 honda 250sx with 300 honda motor
    81 honda 250r
    83 honda atc 110
    84 honda atc 70 with 125 lifan motor
    1,641
    Be a little creative.You can heat and bend it so you can pull it back with your hand.The kickstarter can be set up to stay at rest by the footpeg.
    Jan 2011
    Brazil, Indiana
    2,087
    I made wheel spacers for mine, and cut the fenders.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    OHIO
    2,857
    If you index it more toward the front, it will help out. I cut mine on my old 90cc motor and reworked it to kick to the rear. Works pretty good. Still may bump a stock uncut fender though but barely. There was a thread a long wile ago?? Maybe I can find it.
    Beaver Falls, PA
    2,666
    Quote Originally Posted by hoosierlogger View Post
    I did the same... sorta... I used 400ex hubs and 3x5 offset 8" quad rims, still had to cut the fender , but the kicker cleared the rear tire. I like crazy70man's idea... shorten the kicker.
    Apr 2010
    clarenville
    36
    grea ideas but dident really want to cut/ shave the fenders , when i fiqures it down ill post it up might try and fine a parts 70 around somewhere
    Jordan patey
    81 honda 250r
    83 honda atc 110
