Results 1 to 15 of 25
Thread: O ring chain vs non O ring chain 250r
    jdowd123's Avatar
    jdowd123 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2011
    Homestead fl
    212
    Just bought a 85r that came with a blue chain on it that is a o ring chain. Not a big fan of a blue colored chain. The guy gave me the old that does not have the o rings does it really matter putting a non o ring chain on a 85 250r
    First trike 85 yamaha 125 new in 85
    86 250r full 310 Esr
    86 Tecate Rider Restored
    86 Tecate Oem Restoration in Progress
    86 Big Red Workhorse Love it
    May 2011
    eden,ny
    3,481
    non oring chains require more maintenance And have a shorter life on any machine. Will it drive fine? yes but I would take any oring chain over a standard chain
    Dec 2011
    Grand Rapids, MI.
    679
    I agree, if I am replacing a non o-ring chain I always replace it with an o-ring chain.
    1986 KLT 185
    1984 200S
    Gripit'n'ripit's Avatar
    Gripit'n'ripit is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    Rochester NY
    251
    O-ring all the way.
    81 250R Custom
    83 250R (in progress)
    98 Scrambler 400
    03 Bombardier Quest 500
    07 Polaris Predator (sold to klondike1020 )
    68 VW Dune Buggy
    May 2009
    S.E. Michigan
    1,251
    I think o-ring (or the fancier x-ring) is the way to go. It allows you to be much lazier about chain maintenance without worry about wearing it out too quickly. I'm going on 3 seasons on my 350x with an X-ring chain and haven't really even had to adjust the chain tension since after the initial installation (it isn't stretching or wearing out).
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Mexico
    9,014
    The only places I know of where a non-O ring chain is preferred over an O-ring chain is on a drag bike, or a factory sponsored MX bike that can afford a new chain after a couple of motos. The reason for this is that o ring chains have a fair bit of resistance when cold and something like a drag bike never sees grit anyway. I’d never intentionally run a non O ring chain on any off-road vehicle.
    Blossvale NY
    4,563
    I have a heavy duty X-ring chain on my 350r. I only have to adjust my chain about every 15-20 hours of operation. Mantainence is simple, I use a quality dry o-ring chain lube. Hit it quick before every ride. My chain is holding up to the power and abuse great. Well worth the extra money in my opinion...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Salt Lake City, Utah
    84
    I have heard from honda world a local dealer not to get an o-ring chain if you ride the dunes.. It will wear out faster I guess from all the sand
    Mexico
    9,014
    Yep, I've never regretted spending money on a good chain.
    Mexico
    9,014
    Quote Originally Posted by Mr350x View Post
    I haven't ridden in sand much, but I'd love to hear the reasoning behind that claim if anyone here can explain it to me.
    84
    Ill ask them tomorrow when i go in.. If I remember right he said its because the sand tears up the o-rings
    Dec 2007
    Quebec,Canada
    1,013
    Keep the o-ring chain,if the problem is just the color,paint it
    O-ring chain is a lot better,and quiet compared to a standard chain
    Quote Originally Posted by jdowd123 View Post
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Blossvale NY
    4,563
    I have heard the same thing about running in sand around other circles. Seems I have read advice from duners that the o-rings actually catch and retain sand which takes out the o-rings and wears the links faster. It makes sense to me, but I have no personal experience to back that up.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    fingerlakesny
    2,834
    yep, the o ring chain's are only a few $ more and you DO get what you pay for....
    250r dust runner
    Las Vegas, NV.
    2,483
    All I've ever used are O-ring & X-ring chains, and 90% of my riding is sand. If the sand eroded my O-rings, it wasn't obvious. The links never got any slop in them & the chains hold up just fine. Riding in sand, I'd be more concerned with sand sticking to a freshly lubed chain and causing premature sprocket wear, than I would be about O-ring wear. Either way, the wear is negligible. My last chain purchase was a DID gold X-ring, and I couldn't be happier. It's a great chain at a decent price.
    Here's my order of preference:
    1. X-ring
    2. O-ring
    3. Standard
