Results 1 to 14 of 14
Thread: need a upper chain roller for tri z
    pcs's Avatar
    pcs is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2011
    yuma, az
    465
    been looking around for the upper chain roller from my tri z and i found this one
    http://www.allballsracing.com/79-5008.html
    has anyone here used this one or any other options available
    Team Blue: 85 Tri-z 250: under the knife
    Team Red: 87 Trx250r 01Cr80 15 CBR600RR
    Team Yellow: 06 Ltr450 11 Hayabusa
    Mexico
    9,014
    I don't know if this will help, but I bought a set (don't recall the brand, but nice high end stuff) I was pissed because the bolts they came with were a larger diameter (8mm) than the stock Tri-z hole (6mm) even thought they listed it as suitable. I ended up drilling and tapping my frame to suit the 8mm bolt. You may have to do the same if you can't find some with 6mm thread bolts. You can see them in these photos. Sorry they aren't specificaly of the rollers.
Name:	Yamaha  Upper Roller 1.jpg
ID:	155420Click image for larger version.
Name:	YAMAHA Lower Roller.jpg
ID:	155421Click image for larger version.
Name:	YAMAHA Upper Roller 2.jpg
ID:	155422Click image for larger version.
Name:	YAMAHA Upper Roller 3.jpg
ID:	155423Click image for larger version.
Name:	YAMAHA Upper Roller.jpg
    order a OEM yamaha warrior upper roller!
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    el camexican: from your #1 you posted it looks like a roller from alba racing i saw i ebay, looks good but the bolt size they listed didnt match up, looks real nice.
    bryan: ill try the warrior roller thx
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    hey brian i looked at the warrior roller and the pics show it has no bearing and some of the pics that show show replacements for the tri z show the roller with a bearing, could just be a generic photo. the original was missing on my tri z so im not sure what its suppose to look like. so is it suppose to have a bearing?
    May 2011
    eden,ny
    3,481
    I have a feeling Bryan knows what he is talking about.
    May 2012
    Quote Originally Posted by pcs View Post
    no the oem chain sliders didn't have bearings. You should go with the oem warrior chain sliders they are the same size as the z.
    http://www.ebay.com/itm/YAMAHA-YFM35...0e995f&vxp=mtr
    let me know how it work's .. that might do away with the stupid plastic collar .. and be just one piece!
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    im hoping to get rid of the plastic collar bc it looks ugly, im going to order the ebay all balls. i also noticed i do hot have a swing arm slider, the one that wraps around the front of the swinger by the counter sprocket, is that part tri z specific or will it swap with another atv? the rear chain guide looks like a banshee slider and is where its suppose to be. thx so far for all the help
    go to the 3ww store John makes them .. Hope he's has them in stock! , there discontinued , yes tri z specific.
    Tucson
    1,652
    these are the ones I used on my build! the top one you have to cut the stud off the frame and use the bolt that came with the package, the bottom one is a bolt on deal an both are ball bearings!Click image for larger version.
Name:	Resize of 2012-04-08_18-28-19_61.jpg
ID:	155481Click image for larger version.
    Tucson
    1,652
    the rear slider is a banshee and has to be modified to fit the bracket on the Z swinger, the front one is from john as mentioned above!
    Mexico
    9,014
    Now that you mention it I think I called them up and read them the riot act after I realized they didn't fit. I guess they took notes.
    Rittman, Ohio
    6,276
    Quote Originally Posted by badass350x View Post
    Or you can just get the Warrior rear slider which is the same part as the TriZ.
