Thread: Fat Cat TR 200 swingarm on 200x?
    stevensj13's Avatar
    stevensj13 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Willow Springs, North Carolina, United States
    338
    Hey guys, I've searched google and the site and haven't found a definite answer yet. Does a Honda TR 200 fat cat swingarm bolt up to a 1st gen 200x? Does the jack shaft sprocket setup line up too? I'm guessing I'd have to use a different shock and weld up new shock mounts, but this is a project I'd like to tackle if its feasable. So, can someone tell me for sure wether or not a fat cat swingarm bolts up to a 200x frame and the sprockets for the jack shaft line up or not? I'd love to do this to my 200x if possible. Thanks!
    My baby - 1984 Honda 200X, Clark Desert Tank, Supertrapp exhaust.
    NC
    907
    FYI the Fatcat does not use a jackshaft setup. The case where the countershaft sticks out on the Fatcat, is out further from the center of the cases than the similar 86 87 200x motor which allows it to line up with the rear sprocket. Not saying it won't work or can't be made to work somehow but you may have better luck with a Yamaha BW setup which does use a jackshaft.
    Plattsburgh, NY
    2,311
    Y not just buy a fat cat instead of converting a 200x. U would just be trying to build a fat cat. Honda already did everything for u.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    stevensj13's Avatar
    Jun 2011
    338
    Quote Originally Posted by Tattool23 View Post
    Yamaha big wheels are manual and are supposed to jump and handle better than the fat cat. I might try to trade the 200x for one
    NC
    907
    Quote Originally Posted by stevensj13 View Post
    So why ask if a part will fit a bike you plan to trade?
    stevensj13's Avatar
    Jun 2011
    338
    Quote Originally Posted by 200x350xtriz250 View Post
    I said I might try to trade, as in I might try to trade if I can't get a straight answer on this question.
