Results 1 to 15 of 22
Thread: my rm 80 conversion
    May 2011
    eden,ny
    3,481
    my rm 80 conversion
    this trike isn't finished yet and I was going to wait to post it until it is but with other 80's popping up I figured I would post it up. I picked up the donor bike in the begining of july and got to work on it right away. my original plan for the swingarm was to mate the rm swinger with some type of atv swinger but I decided that looked like too much work to get everything righ,t so I went digging into my spare tecate parts. I had a complete swingarm,axle,ect.. for an 85 tecate. the next issue was to make it fit the rm with minimal changes. The swingarm was way to wide to fit in the frame but I did find that the chain would line perfect if I could get it in there. To get the swingarm to mount I cut the right side off and moved it over an inch welded plate on that side for strength and appearance. Since all the shock linkage is mounted on the frame of the rm with one link mounting on the swingarm all I need to do was weld the mounts onto the swingarm. It took some investigating to find a rear sprocket that would work,I ended up using a crf/xr 100 rear sprocket since the inside diameter is the same as the 1st gen t3 (80mm) I filled the original bolt holes with weld and redrilled the hub for the xr sprocket.Perfect fit and is a common sprocket. The next issue that need to be addresed was the front end.Iwas going to cut and reweld the triples but by chance I stumbled acrossed a post on here saying the 85 tri z had 35mm forks,the same as the rm. On the hunt for 85 z triples I went. I didnt wanna spend too much since I didn't know how it would work out,I ended up scoring a set on ebay for 20.00 shipped. I knew I would have an issue with the steering stem and came up with an idea to resolve that issue. The z stem was a larger diameter than the rm so I made a bushing that would press into the lower triple then the rm stem pressed into the bushing,worked great.I could have used the whole front end setup from an 85 z but I wanted a smaller front wheel to keep the proportions correct. The wheel I wanted to use was 8x5 1/2 with a 4x110 bolt pattern. so I ordered a front hub from spanglers offroad (not too impressed with it) I had it sent un assembled so it could be customized for my application. the wheel has a 2 1/4 x 3 1/4 offset so the wheel is off set 1". Being confident in my measurements I went ahead and welded it up. That was a stupid mistake the wheel ended up 1" off,I still don't really understand that but it was done and nothing I could do at that point so I ordered an 1 1/4 wheel spacer and turned it down to 1" not really how I wanted to do it but it works for now. The next issue was the fork rake,no big deal just chop and weld.I ended bringing the rake in 9 degrees which seems pretty good,if I bring it in any more I will have to stretch the frame which may still happen after extenive testing but it seems to handle good the way it is. for the rear fenders I was originally planning to use t3 fenders since I have them and they already have the cut out for the kickstart. After setting them on the trike I decided that was n ot the way to go.The fit was terrible the seat was way to big and it just looked bad. So I took a look around and came up with the seat and fenders from a monsoon/yerf dog quad which worked out well since I already stole a wheel and tire from it for the front. The fenders are badly faded and I hate sanding and polishing so I was able to find 2 pair of nos fenders on ebay the price was right so I bought both pairs. That is where I'm at so far with this build,I still need to change the foot pegs out and do some more cosmetic work on it but so far I am pleased with it. Heres a few pics for yaClick image for larger version.
Name:	old pics 590.jpg
ID:	152861Click image for larger version.
Name:	old pics 592.jpg
ID:	152862Click image for larger version.
Name:	old pics 594.jpg
ID:	152863Click image for larger version.
Name:	old pics 596.jpg
ID:	152864Click image for larger version.
Name:	old pics 639.jpg
ID:	152865Click image for larger version.
Name:	old pics 646.jpg
    Very nice Ben. Sweet little creation!
    Jun 2011
    southern california
    125
    thats a sweet trike i bet it halls ass
    Sep 2011
    oswego ny
    70
    nice job ben looks good cant wait to.see it
    Afrothunderkat's Avatar
    Afrothunderkat is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    Richmond NH
    336
    Love zooks, AWESOME!
    2003 RM 250 ::: 1985 ATC 250R ::: 1986 ATC 250ES
    Past Trikes: 1985 YTM 225DX ::: 1984 200s ::: 1985 YTM200
    Past Bikes: 1987 KX80BW ::: 2002 TT-R 125L ::: 2000 RM 125
    Quote Originally Posted by Tri-ZNate View Post
    Talking about the build quality, I got their exhaust and economy muffler and it fits together like tossing a hot dog down a hall way with nothing provided to take up the slop. Best $200 ever spent
    Carthage NY 250r rules
    2,355
    Very cool.Love these 80 build threads.
    250r rules
    Manheim, PA
    5,816
    looks better as a 3wheeler, seat look very very high but im sure you'll adress that later. good job so far
    Springfield Mo
    3,309
    Let's see some more pics!!
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Gold Hill, OR
    1,295
    Nice job Ben! X2 on more pics. I liked the video of it too, it sounds like it would smoke my Tecate lol
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    May 2011
    eden,ny
    3,481
    I have the front wheel off at the moment because atc70.com can't sell parts that fit together so I have to true the rotor mount. I will get some more pics up soon,it' still a work in progress. I would like to see how it would stand up next to my tecate,once you get that little booger wound up it just flies
    May 2011
    eden,ny
    3,481
    a few more pics
    ok heres a few more pics. I still have a few things to do: new rear wheels,make a grab bar,a different front fender and probably a few other things. I tossed in a pic of my shoe tree hauler just because it was outClick image for larger version.
ID:	158282Click image for larger version.
ID:	158283Click image for larger version.
ID:	158284Click image for larger version.
ID:	158285Click image for larger version.
ID:	158286Click image for larger version.
ID:	158287Click image for larger version.
ID:	158288Click image for larger version.
    Plattsburgh, NY
    2,311
    What rear fenders r those on that atc 70 ??
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Nov 2010
    Oshawa, On, Canada
    2,123
    Sweet man!
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Jul 2011
    Lilly PA
    1,480
    Did you get the axle on the shoe tree hauler fixed up how you wanted? Still think that 80 conversion is gonna tear up some shiznit!! Great job Ben
    Just sit back and chillaxx
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by Tattool23 View Post
    They are made by a guy in minnesota cheaper than maier's and look alot better. I will see if I can post a link to his contact info if you want it.edit.. heres a link with how to get ahold of him. good luck though. After several emails to him I contacted mr.twisted wheelers and had them in a few days http://www.3wheelerworld.com/showthr...th-this-seller
