Hey everyone,
I was thinking about locating a shop to have a set of wheels and my rear axle redone (with the gold anodizing) and I discovered this article online, which if I have read correctly, basically says that it is possible to achieve the same gold tint/finish, but with the correct paint mixture (completely separate of the anodizing process).
" The anodized layer of the metal is aluminum oxide, which absorbs the gold dye. The PRINCIPAL of achieving the desired color is the same: With anodizing a colored transparent dye soaks into the raw anodize surface and colors it "GOLD". Similarly, a just-right mix of transparent yellow and clear, applied over clean aluminum can duplicate that look. "
I was thinking about contacting Mike (vintagemotorsports) regarding his restorations but I'd like to explore this also. In the article, the author references "Dupli color" as one of the brands used in his attempts to recreate the gold anodized appearance on some auto parts - Has anyone had a similar experience, or found a paint color/mixture which can achieve this desired effect?
Here's the link to the full thread -
http://www.finishing.com/264/17.shtml
