Looking for some help on my 200x front brake. First some background.
1985 200x front caliper and master. Master is rebuilt and caliper is rebuilt. I am using a SS brake line.
So went out to add fluid and bleed and 4 hours later I am in the same spot as I was at 11am...NO FRONT BRAKES!
bled the breaks with a mighty-vac. No air in the lines and no pressure either. I then took off the master, ensured everything was in the correct place, reblew all the lines and master cylinder holes with air. I then re-bled and still no pressure. Piston isn't actuating...nothing.
All the lines are tight and fluid isn't leaking anywhere.
Can somebody tell me what I am missing?
Thanks in advance!
