What rims will work if have a 1980 185 s Honda. Make and years
No ones wants to help
Its an odd ball size 4x155mm I believe so stock is best unless you change the rear hubs to a atc200x and use the common 4x110mm and the rim choice is simple and vast LOL .
Those who can ride, ride...those who can't, drive.
I bet you don't have a 1980 185s...
Assuming it's the big tire 185, it came with 9" diameter rims with a 4x150 bolt pattern. So, check out this chart for other 4x150 ATVs:
http://www.pureoffroad.com/ATV_Wheel...tern_Guide.htm
Other options are to change your rear hubs like Shortline said - hubs from nearly every other Honda ATV ever made bolt on except 85+ 250R and 85+350x. But, you're stuck with the front hub.
Rear hub I think might be wrong. The rim was split. It like dbl rim or something. In can touch the tube in side rim. But it air up . Have seen a rim like this.
Rear hub I think might be wrong. The rim was split. It like dbl rim or something. In can touch the tube in side rim. But it air up . Have seen a rim like this. Ok. The bolt wher the wrong size. It was not bolt straight. But have two 185 so toke the one off it tell can get new hub at least.
Oh - interesting.
81 185s came with 3 bolt hubs and split rims. 3x100 bolt pattern like most Hondas up to that point. Either way, the 3 bolt hubs bolt right on the axle.
The rest of the answer is still the same. Without changing hubs, you're looking at ATC70,90,110,185s,FL250 and Maybe Tri-Moto and one or two old Suzukis.
I just picked up a 1982 185 a few days ago. I'll take a look at the rims tomorrow.![]()
Current Trikes
2 1985 Honda 250sx
1985 Big Red
2 1983 YTM 200k's. 1 for parts.
KLT 250 Prairie
1982 Honda 185 - Waiting to be saved
1985 125m Parts Machine
Still on the hunt for a 1986 350x and 250r.
Current rides
Taurus 650 (green)
85 250es big red
82 ALT50
82 ALT50
71 QA50
93 TRX 300 FW
