Results 1 to 7 of 7
Thread: big red 250 top speed? and differences between trx 250 and big red
    Aregistereduser is offline At The Back Of The Pack Arm chair racerFirst time rider
    new york
    187
    my big red seems to start working itself pretty hard at 40 or so mph. seems like i only get to give it quarter throttle in any gear if i dont wanna over rev it, is that normal? i know it aint a speed demon but i feel like it should go 45 without a sweat. and i was also curious if the trx 250 and big red share the same tranny and engine, rear end,carb and such.
    Sarnia, Ontario, Canada
    3,415
    what size tires are you running?? does it sound like like it's slipping or just overrevving?
    if you are talking about a 86-87 trx250, yes these two machines are the same..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    new york
    187
    running the orginal 25 inch tires that it came with. and it sounds like over revving.
    Apr 2006
    London Ontario, Canada
    1,196
    might be time for a new clutch...
    Tapper
    R.I.P. Sandpuppie, you are greatly missed!
    May you rest in peace Jeswinehart, deeply missed, never forgotten....
    Feedback thread http://www.3wheelerworld.com/showthr...ight=tapper190
    NEPA
    7,049
    ^^ Agreed,,slipping clutch/clutches. And assuming your BR is 85,,there are MANY small differences throughout the entire driveline. From the starter and gears,oil pump,tranny right back thru the diff. But replaced as a unit,they mostly work together. The 85's have a 3/16 lip around the diff housing,left side,the newer ones are flush,both hubs are different,swingarms are different... My neighbors 86 TRX flat layed it on my Big Red,,I had probably 50? lbs on him. But there is def a gearing difference ! I'm assuming he's putting a whooping on your BR ? lol
    new york
    187
    my big red is a 86, and this fourtrax 250 is also a 86, i just purchased it today(the quad) after getting responses on this thread, the fourtrax is said to have had a shaved head, but if it was i honestly barely feel a difference, maybe 2hp. but anyways the trx is a bit quicker, i was driving it home and as soon as i got in the drive way the front left tire rolls ahead of me (new three wheeler yay ).... bearings were shot. talk about good luck could of been a nasty wreck on the trails. but thank you all for the info.
    NEPA
    7,049
    86 to 86 are virtually the same right back through. Those quads will do that !!
