Reeds do nothing for adding horse power, unless you are replacing stock steel reeds, that take more effort from intake draw to operate. Also removing the stopper plates will let them open further in theory.
Reed's basically move power curves around, unless you install or modify a larger cage in conjunction with jetting and carb work. Many reeds are designed to add low end hit by adding a second layer of stiffer pedals over top the first layer, to make the engine pull more lower RPM torque. You see that more with small bore 2 strokes.
If you picture what a cam and valves do for a 4 stroke with intake and Exhaust duration and valve lift, most of that, is accomplished on a 2 stroke in jug and piston port timing..The reeds have nothing to do with adding power..If you want more power on a 4 stroke, you play with cam and porting..To get that same effect on a 2 stroke, you port your jug..All reeds do, is let the engine hit into the topend sooner or later. On a bigbore/stroker 2 stroke, reeds could come into play some with adding power, but mostly the cage size and flow is what matters to assist the stroker bigbore engine.
As far as fuel mileage, honestly who could, or want to waist the time in even trying to calculate it. The variables and outcomes are too inconsistent and subtle to even compare..
Proudly NOT a member of
"Team on the Teat"
