On the slow road to fixing up my 86 x. I noticed a wobble in the rear end as I rode down the road. Axle carrier bearings was worn so I replaced them. Still a wobble. Rear wheels where bent. I replaced them. Still a wobble. I set the bike up on my lift and let it run in gear as I watched. Axle is slightly bent on the left end.
Heres where my questions come into play. Should I take this to the machine shop and have them try to straighten it? The splines are in great shape so is the threads. Will this make it weaker? I just torn the axle out of the bike and I cant figure out if the hub that holds the sprocket on comes off. I just looked at the manual and It doesnt show them removing it. It looks like it comes off its on splines. How does it come off?
